[Tips] For Phantom 4 RTK, Phantom 4 Pro V2.0, and Phantom 4 Pro + V2.0, you don’t need to switch modes of the remote controller.
Follow the instructions below to switch the remote controller mode:
1. Close DJI Assistant 2 and open DJI Terra (DJI Assistant 2 and DJI Terra cannot run together on the same computer).
2. Login to your DJI account.
3. Connect the Micro-USB port on the back of the remote controller to the USB port on the computer with a Micro-USB cable.
4. Turn on the remote controller and switch the flight mode to P mode. On the DJI Terra interface, select Settings (icon) > Remote Controller (icon), then enable "Switch to PC Mode" or "Switch to App Mode".
5. Disconnect the Micro-USB cable, restart the remote controller, and connect the USB port on remote controller to the USB port on the computer with an A male to A male USB cable. At this point, the DJI Terra interface will display the location and status information of the aircraft.
