1. Flight Mission:
Phantom 4 Pro V2.0, Phantom 4 Pro+ V2.0, Phantom 4 RTK (Remote Controller with a built-in screen), Phantom 4 Pro, Phantom 4 Advanced, Phantom 4.
💡 [Tips] P4 Multispectral does not support direct connection to DJI Terra for flight, only supports map importing after the flight.
2. Real-time 2D Mapping:
Phantom 4 Pro V2.0, Phantom 4 Pro+ V2.0, Phantom 4 RTK (Remote Controller with a built-in screen), Phantom 4 Pro, Phantom 4 Advanced.
3. Real-time 3D Mapping:
Phantom 4 RTK (Remote Controller with a built-in screen), Phantom 4 Pro V2.0, Phantom 4 Pro+ V2.0.
💡 [Tips]
① Starting from v2.3.3, DJI supports real-time 3D reconstruction, which allows users to choose real-time 3D point cloud and real-time 3D model.
② Real-time 3D quality is affected by RTK signals.
4. Detailed Inspection, Flight Route Planning, and Exporting:
This feature was added starting from DJI Terra v2.3.3, supporting the following models: Phantom 4 RTK, Mavic 2 Enterprise Advanced, Mavic 3E, Mavic 3T, Matrice 30 Series, Matrice 300 RTK + Zenmuse H20 Series, DJI Matrice 4T, DJI Matrice 4E, DJI Matrice 4D, DJI Matrice 4TD. It does not support other drones for executing flight missions, except for the Phantom 4 RTK.
5. LiDAR Point Cloud Processing:
Zenmuse L1 and Zenmuse L2 are supported. Currently it does not support third-party devices.
6. Multispectral Reconstruction:
P4 Multispectral and Mavic 3M.
7. Theoretically, the Visible Light Reconstruction function is supported on all camera models. However, we do not guarantee that all camera footage is supported. Use DJI mapping camera as a priority, and using third-party cameras requires entering correct camera parameters.
💡 [Tips] DJI Terra V5.0.0 no longer supports flight missions other than detailed inspection and agricultural applications. If you need to use the flight function, please use V4.5.0 or lower versions of the software
