What is QuickShots?
QuickShots is an intelligent flight function of the DJI Lito Series, DJI Flip, DJI Avata 360, DJI Neo, DJI Air Series, DJI Mavic Series, DJI Mini Series, and Spark Series drones. QuickShots shooting modes include Dronie, Rocket, Circle, Helix, Boomerang, and Asteroid. The aircraft records according to the selected shooting mode and automatically generates a short video. The video can be viewed, edited, or shared on social media from playback.
Note: DJI Avata 360:DJI RC Motion 3, DJI FPV Controle Remoto 3 control does not support quickshots.
Introduction to QuickShots Modes
Dronie
The aircraft flies backward and ascends, with the camera locked on the subject, and records a video.
(The flight distance varies based on different models.
Product model
Flight Distance
DJI Mini SE
Mavic Mini
The default value is 25m and the setting range is 25m-40m.
DJI Mini 2
DJI Mini 2 SE
DJI Mini 4K
Mavic Air 2
DJI Air 2S
DJI Mavic 3 Series
The default value is 25m and the setting range is 25m-120m.
DJI Lito 1
DJI Lito X1
DJI Avata 360
DJI Mini 5 Pro
DJI Mavic 4 Pro
DJI Air 3S
DJI Mini 4 Pro
DJI Air 3
DJI Mini 3 Pro
DJI Mini 3
The default value is 30m and the setting range is 30m-120m.
DJI Neo 2
The default value is 4m and the setting range is 2m-20m.
The default value is 4m and the setting range is 2m-10m.
Helix
The aircraft ascends and spirals around the subject.
(The flight distance varies based on different models, and the flight direction can be set.
Product model
Inspection distance
DJI Mini SE
Mavic Mini
The default value is 25m and the setting range is 10m-40m.
DJI Mavic 3 Series
Default 25 meters, adjustable range 20-120 meters.
DJI Avata 360
DJI Mavic 4 Pro
DJI Mini 2
DJI Mini 2 SE
DJI Mini 4K
Mavic Air 2
DJI Air 2S
The default value is 10m and the setting range is 10m-120m.
DJI Lito 1
DJI Lito X1
DJI Mini 5 Pro
DJI Air 3S
DJI Mini 4 Pro
DJI Air 3
DJI Mini 3 Pro
DJI Mini 3
The default value is 30m and the setting range is 10m-120m.
DJI Neo 2
The default value is 4m and the setting range is 4m-20m.
Rocket
The aircraft ascends with the camera pointing downward.
(The flight distance varies based on different models.)
Product model
Inspection distance
DJI Mini SE
Mavic Mini
DJI Mini 2
DJI Mini 2 SE
DJI Mini 4K
Mavic Air 2
DJI Air 2S
DJI Mavic 3 Series
The default value is 25 m and the setting range is 25m-80m.
DJI Lito 1
DJI Lito X1
DJI Avata 360
DJI Mini 5 Pro
DJI Mavic 4 Pro
DJI Air 3S
DJI Mini 4 Pro
DJI Air 3
DJI Mini 3 Pro
DJI Mini 3
The default value is 30 m and the setting range is 30m-80m.
DJI Neo 2
The default value is 4m and the setting range is 4m-10m.
Circle
The aircraft circles around the subject.
Only the DJI Flip and DJI Avata 360, DJI Neo 2, DJI Neo can set the distance; the flight direction can be set for the following applicable products.
Applicable products: DJI Lito 1, DJI Lito X1, DJI Avata 360,DJI Neo 2,DJI Mini 5 Po, DJI Mavic 4 Pro, DJI Flip, DJI Air 3S, DJI Neo, DJI Mini 4 Pro, DJI Air 3, DJI Mavic 3 Series, DJI Mini Series, Mavic Air 2, DJI Air 2S, and DJI Mini 3 Pro, DJI Mini 3,御 Mavic 2 Zoom,御 Mavic 2 Pro,Mavic Air (remote controller), 御 Mavic Air(WiFi),Spark (remote controller),Spark(WiFi)。
Boomerang
The aircraft flies around the subject in an oval path, ascending as it flies away from its starting point and descending as it flies back. The aircraft’s starting point forms one end of the oval’s long axis, while the other end is at the subject's opposite side from the starting point. Make sure there is sufficient space when using Boomerang. Allow a radius of at least 99 ft (30 m) around the aircraft and at least 33 ft (10 m) above the aircraft. The flight direction can be set.
Applicable products: DJI Lito 1, DJI Lito X1, DJI Avata 360,DJI Neo 2, DJI Mini 5 Pro, DJI Mavic 4 Pro, DJI Flip,DJI Neo,DJI Air 3S, DJI Mini 4 Pro, DJI Air 3, DJI Mini 2, Mavic Air 2, DJI Air 2S, DJI Mavic 3 Series, and DJI Mini 3 Pro, DJI Mini 3,DJI Mini 2,Mini 2 SE,DJI Mini 4K,御 Mavic 2 Zoom,御 Mavic 2 Pro,御 Mavic Air((remote controller),御 Mavic Air(WiFi)。
Asteroid
The aircraft flies backward and upward, takes several photos, and then returns to the starting point. The video starts with a panorama of the highest position and then shows the descent. Make sure there is sufficient space when using Asteroid. Allow at least 132 ft (40 m) behind and 164 ft (50 m) above the aircraft.The flight direction and distance cannot be set.
Applicable products: DJI Lito 1, DJI Lito X1, DJI Avata 360, DJI Mini 5 Pro, DJI Air 3S, DJI Mini 4 Pro, DJI Air 3, Mavic Air 2, DJI Air 2S, DJI Mavic 3 Series, and DJI Mini 3 Pro, DJI Mini 3,御 Mavic 2 Zoom,御 Mavic 2 Pro,御 Mavic Air((remote controlle),御 Mavic Air(WiFi)。
Using QuickShots
Please use QuickShots at locations that are clear of the building and other obstacles. If you are unfamiliar with the flight path of “QuickShots,” please do a short flight on the first attempt.
1. Tap the shooting mode icon on the right side of the camera view.
2. Swipe down and select “QuickShots”. Then choose a “QuickShots” shooting mode.
3. Select your target subject in the camera view by tapping “+” or drag-select the target. Tap “Start” to begin recording.
Watch this video to learn about how to use QuickShots:
Existing QuickShots
Press the Flight Pause/RTH button of the remote controller once or tap “X” in DJI Fly to exit QuickShots. The aircraft will brake and hover in place.
Resolution of QuickShots
Product Model
QuickShots
Resolution
fps
Video Format
DJI Lito 1
DJI Lito X1
Dronie
1080P/2.7K/4K
30/60
MP4
Helix
Circle
Boomerang
Rocket
Asteroid
DJI Avata 360
Circle
360° Mode Lens:
8K (2:1): 7680 × 3840@60/50/48/30/25/24fps
6K (2:1): 6000 × 3000@60/5
24/25/30/48/50/60
MP4
Boomerang
Dronie
Rocket
Helix
Spin
DJI Neo 2
Circle
1080P
4K
30/50/60
MP4
Boomerang
Dronie
Rocket
Helix
DJI Mini 5 Pro
Circle
1080P
4K
30/60
MP4
Boomerang
Dronie
Rocket
Helix
Asteroid
DJI Mavic 4 Pro
Rotation
1080P
4K
6K
30/60
MP4
Circle
Boomerang
Dronie
Rocket
Helix
Asteroid(The Medium and Tele Camera is not effective)
1080P
30
DJI Mini 4 Pro
Circle
1080P
4K
30/60
MP4
Boomerang
Dronie
Rocket
Helix
Asteroid
Circle
1080P
1080P(9:16)
2.7K
4K
30/60
MP4
Boomerang
Dronie
Rocket
Helix
Asteroid
1080P
30
MP4
Circle
1080P
4K
30/60
MP4
Boomerang
Dronie
Rocket
Helix
Asteroid
DJI Air 3S
Dronie
1080P
2.7K(9:16)
4K
30/60
MP4
Helix
Circle
Boomerang
Rocket
Asteroid (The 3x scope is not working)
1080P
30
DJI Air 3
Dronie
1080P
1080P(9:16)
2.7K(9:16)
4K
30/60
MP4
Helix
Circle
Boomerang
Rocket
Asteroid(The 3x scope is not working)
1080P
30
DJI Mini 3
Dronie
1080P
2.7K
4K
30
MP4
Helix
Circle
Boomerang
Rocket
1080P
DJI Mini 3 Pro
Dronie
1080P
2.7K
4K
30
MP4/MOV
Helix
Circle
Boomerang
Rocket
Asteroid
1080P
DJI Mavic 3 Pro
DJI Mavic 3
DJI Mavic 3 Classic
Dronie
1080P
4K
30
MP4/MOV
Helix
Circle
Boomerang
Rocket
Asteroid
1080P
DJI Mini SE
DJI Mini 2 SE
Helix
1080P
2.7K
30
MP4/MOV
Dronie
Circle
Boomerang
Rocket
DJI Air 2S
Dronie
1080P
2.7K
4K
30
MP4/MOV
Helix
Circle
Boomerang
Rocket
Asteroid
1080P
DJI Mini 2
Dronie
1080P
2.7K
4K
30
MP4/MOV
Helix
Circle
Boomerang
Rocket
Mavic Air 2
Dronie
1080P
2.7K
4K
30
MP4/MOV
Helix
Circle
Boomerang
Rocket
Asteroid
1080P
Mavic Mini
Dronie
1080P
2.7K
2.7K: 24/25/30fps
1080P: 24/25/30/48/50/60fps
MP4
Circle
Boomerang
Rocket
Mavic 2
Dronie
1080P
30
MP4/MOV
Helix
Circle
Boomerang
Rocket
Asteroid
Mavic Air
Dronie
1080P
30
MP4/MOV
Helix
Circle
Boomerang
Rocket
Asteroid
To understand the DJI GO 4 Quick Shots, read: Introduction to QuickShots via DJI GO 4
