Circumstances in which linking is required
Brand-new aircraft have already been linked upon shipment. Therefore, you can use your newly purchased device without linking.
However, in the event of the following circumstances, please re-link the aircraft before use.
1. The aircraft may fail to connect to the remote controller if its firmware is incompatible or a firmware update fails. Please re-update the firmware and re-link the aircraft and remote controller before use.
Consult the content below for solutions to a firmware update failure: Aircraft Firmware Update Failure
2. If you have used the DJI Care Refresh replacement benefit, please activate and link the aircraft before use.
3. If the core board of your aircraft or remote controller has been replaced during repair, please re-activate the aircraft, and re-link it before use.
Refer to the following steps for more details about the aircraft linking guide:
Linking Tutorial
View the tutorial below for a step-by-step guide to linking.
DJI Mavic 4 Pro
If you purchase an aircraft and remote controller combo, the remote controller is already linked to the aircraft upon shipment. You can use them directly after activation upon powering on. In other cases, please refer to the tutorial video for linking.
• DJI RC Pro 2
• DJI RC 2 (Taking DJI Air 3 as an example)
If you purchase a DJI Flip together with a remote controller, the remote controller is already linked to the aircraft upon shipment. You can use them directly after activation upon powering on. In other cases, please check out the video in the following.
• DJI RC-N3 Remote Controller: Requires connection to a mobile device. The tutorial uses DJI Neo as an example.
• DJI RC 2 Remote Controller: The tutorial uses DJI Air 3 as an example.
DJI Air 3S/DJI Air 3
Refer to the video below to learn how to link DJI Air 3S to DJI RC 2:
DJI Neo 2/DJI Neo
• Link DJI Neo to DJI RC-N3
• Link DJI Neo to Goggles
DJI Mini 2/DJI Mini 2 SE/DJI Mini 4K
DJI Avata 2
DJI Avata 2, DJI Goggles 3 and DJI RC Motion 3 are already linked when purchased together as a combo. In this scenario, you can use them immediately after activation and powering on. Otherwise, follow the instructions below to link them:
• Linking the drone with the DJI Goggles 3:
• Linking the goggles with the remote control device
DJI Mini 5 Pro/DJI Mini 4 Pro
The remote controller is already linked to the aircraft when purchased together as a combo. Otherwise, follow the steps below to link the remote controller and the aircraft after activation.
1. Power on the aircraft and the remote controller;
2. Launch DJI Fly;
3. In camera view, tap and select Control and then Re-pair to Aircraft. During linking, the status LED of the remote controller blinks blue, and the remote controller beeps;
4. Press and hold the power button of the aircraft for more than four seconds. The aircraft beeps once, and its battery-level LEDs blink in sequence to indicate it is ready to link. The remote controller will beep twice, and its status LED will turn solid green to indicate linking is successful.
The following video takes the DJI Mini 3 Pro as an example to introduce you to the linking operation:
DJI Mavic 3 Pro
DJI Mini 3
DJI Mavic 3
DJI Mini 3 Pro
DJI Air 2S/Mavic Air 2
DJI Mini SE
Mavic Air
Phantom 4 Pro/2.0
Linking with the App
For Products Compatible with the DJI Fly App
1. Connect the aircraft and the remote controller to a mobile device (Do not connect the remote controller with a built-in screen to a mobile device).
2. In the Camera View of the DJI Fly app, tap “...” in the top right corner to enter the Control interface, and then tap “Re-pair to Aircraft (Link)”.
3. Press and hold the aircraft power button. After entering linking mode successfully, the aircraft will beep once, and will beep twice once it is linked successfully.  When the battery level indicators on the remote controller stop blinking and become solid, it indicates that the linking was successful.
For Products Compatible with the DJI GO 4 App
2. In the Camera View of the DJI GO 4 app, tap the “...” icon in the top right corner, and select “Remote Controller Settings”, then tap “Remote Controller Linking” at the bottom of the screen.
For products compatible with the DJI GO 4 app, find the link button in the position as shown in the figure below.
1. Phantom 4 Pro V2.0 or Phantom 4 Pro
2. Mavic 2 Zoom or Mavic 2 Pro
3. Mavic Air
4. Inspire 2
 If the aircraft linking fails, please check: Aircraft Linking Failure
