Learn More Osmo Series Product Charging Failure
Osmo Nano
Use a USB-C charger that complies with the standard PD 3.0 protocol and has a maximum output power of 30W or higher to charge.
Open the USB-C port cover, and use the included charging cable to connect the USB-C port to the charger.
Osmo 360
• Charging via the USB-C port.
Note: It is recommended to use a USB-C charger that supports PPS or PD.
• Charging via the multifunctional battery case.
Osmo Mobile Series
Osmo Mobile 8P/Osmo Mobile 8
Use the included power cable (USB-C to USB-C, 50 cm) to charge your gimbal until the battery level indicator turns off. In just 2.5 hours, the gimbal will be fully charged and ready to unleash your creativity!
💡[Tips] Enjoy up to 10 hours of battery life when the gimbal is balanced and stationary. Please note that actual usage time may vary depending on accessories, balance, and how features are used.
Osmo Mobile 8P
Osmo Mobile 8
Osmo Mobile 7P
Osmo Mobile 7
Use the included power cable (USB-C to USB-C, 50 cm) to charge your gimbal until the battery level indicator turns off. In just 150 minutes, the gimbal will be fully charged and ready to unleash your creativity!
Osmo Mobile 6
Connect the USB-C charger to the USB-C port on the right side of the product, and the battery can be fully charged in about 84 minutes by the charger with a maximum charging power of 10 W. After the battery is fully charged,the battery indicator icon on the status display panel is off. Remove the charger after charging is complete.
Osmo Mobile SE
Connect the USB-C charger to the USB-C port on the right side of the product, and the battery can be fully charged in about 132 minutes by the charger with a maximum charging power of 10 W. After the battery is fully charged, the battery indicator icon on the status display panel is off. Remove the charger after charging is complete.
DJI OM 5
Connect the USB-C charger to the USB-C port on the right side of the product, and the battery can be fully charged in about 90 minutes by the charger with a maximum charging power of 10 W. After the battery is fully charged, the Status LED turns off. Remove the charger after charging is complete.
DJI OM 4 & DJI OM 4 SE
Connect the USB-C charger to the USB-C port on the right side of the product, and the battery can be fully charged in about 150 minutes by the charger with a maximum charging power of 10 W. After the battery is fully charged, the Status LED turns off. Remove the charger after charging is complete.
Osmo Mobile 3
Osmo Action Series
Osmo Action 6
Osmo Action 5 Pro
Installing the Battery: Press the Release button on the battery compartment cover, push the cover forward, and insert the battery into the battery compartment after opening the cover.
Charging Method: Press the Release button on the USB-C port cover and slide the cover down. Connect a charger to the USB-C port using the Type-C to Type-C PD cable included in the package. It takes about 53 minutes to fully charge the battery.
It is recommended to use the charging devices provided by DJI, such as DJI 30W USB-C Charger or other USB-C chargers that support Power Delivery or PPS.
• Osmo Action Multifunctional Battery Case
Through the USB-C port, the battery case is capable of charging three extreme batteries simultaneously, taking approximately 2 hours and 25 minutes to fully charge all of them. Additionally, it has the capacity to charge external devices such as smartphones.
Note: The battery case can store two microSD cards.
Osmo Action 4/Osmo Action 3
Press the Release button on the USB-C port cover and slide the cover down. Connect the USB-C charger to the USB-C port, and the battery can be fully charged in about 58 minutes by using the DJI 30W USB-C Charger. After the battery is fully charged, the Status LED turns off. Remove the charger after charging is complete.
It is recommended to use the DJI 30W USB-C Charger or a USB-C charger that supports PPS/PD fast charging protocol, along with the USB-C to USB-C PD Cable provided in the combo, to charge the Osmo Action 4/Osmo Action 3.
Charging Using the DJI 30W USB-C Cable
Power off the camera, and connect it to a charger via the DJI 30W USB-C Cable. The status LEDs blink green during the charging process, and turn off when the battery is fully charged. It takes about 18 minutes to charge the battery to 80%, and the battery can be fully charged in about 49 minutes.
Charging the Camera Using the Multifunctional Battery Case
Connect the multifunctional battery case to a power source using the DJI 30W USB-C Charger. The batteries with the highest power level will be charged first, followed by the remaining batteries to be charged in sequence. It takes approximately two hours to fully charge three batteries.
DJI Action 2
Connect the USB-C charger to the USB-C port on the right side of the front touchscreen module or the power module. The battery can be fully charged in about 1 hours and 30 minutes by the charger with a maximum charging power of 10 W. After the battery is fully charged, the Status LED turns off. Remove the charger after charging is complete.
Press the cover release button on the USB-C cover and slide the cover down. Connect the USB-C charger to the USB-C port, and the battery can be fully charged in about 1 hours and 30 minutes by the charger with a maximum charging power of 10 W. After the battery is fully charged, the Status LED turns off. Remove the charger after charging is complete.
Osmo Pocket Series
Osmo Pocket 4P
It is recommended to use DJI 65W Portable Charger, 30W USB-C Charger, or a USB-C charger that supports PD fast charging protocol. When charging Osmo Pocket 4P with the Type-C to Type-C PD Cable provided in the combo, the camera screen will display the current battery level when the camera is off. (Note: When Super Fast Charging is triggered, a “lightning bolt” icon will be displayed.) The camera takes approximately 18 minutes to charge up to 80% state of charge (SoC), and around 32 minutes to fully charge*.
* Tested in a laboratory environment with the DJI 65W PD charger (sold separately).
Osmo Pocket 4
It is recommended to use DJI 65W Portable Charger, 30W USB-C Charger, or a USB-C charger that supports PD fast charging protocol. When charging Osmo Pocket 4 with the Type-C to Type-C PD Cable provided in the combo, the camera screen will display the current battery level when the camera is off. (Note: When Super Fast Charging is triggered, a “lightning bolt” icon will be displayed.) The camera takes approximately 18 minutes to charge up to 80% state of charge (SoC), and around 32 minutes to fully charge*.
Osmo Pocket 3
It is recommended to use DJI 65W Portable Charger, 30W USB-C Charger, or a USB-C charger that supports PD fast charging protocol. When charging Osmo Pocket 3 with the Type-C to Type-C PD Cable provided in the combo, the camera screen will display the current battery level when the camera is off. (Note: The screen prompts “Fast Charging” when fast charging is triggered, and prompts “Charging” when in normal charging state.) The camera takes approximately 16 minutes to charge up to 80% state of charge (SoC), and around 32 minutes to fully charge*.
DJI Pocket 2
Connect the USB-C charger to the USB-C port at the bottom of DJI Pocket 2, and the battery can be fully charged in about 1 hours and 13 minutes by the charger with a maximum charging power of 10 W. After the battery is fully charged, the Status LED turns off. Remove the charger after charging is complete.
Connect the USB-C charger to the USB-C port at the bottom of the product, and the battery can be fully charged in about 1 hours and 13 minutes by the charger with a maximum charging power of 10W. After the battery is fully charged, the Status LED turns off. Remove the charger after charging is complete.
