Osmo Pocket Series
Issue Description
1. There is no response when tapping the shutter button on the app.
2. There is no response when pressing the shutter button on the product.
Possible Cause of Issue
If there is no response when tapping the shutter button on the app:
1. The microSD card is incompatible, or there is an error with the microSD card.
2. There is an error with the app.
3. The shutter button is malfunctioning.
Solution
Update the DJI Mimo app to the latest version, and restart the app. Then use a microSD card compatible with the Osmo Pocket series product. Go to “Specifications” on the Product Page of the DJI official website to learn about compatible microSD cards.
If the microSD card is compatible, please save the photos/videos already on the microSD card, format the microSD card, and insert it into the Osmo Pocket series product again.
* If possible, try to use another microSD card.
* Formatting the microSD card using the DJI Mimo app as follows:
If there is no response when pressing the shutter button on the product:
1. A firmware error causes this issue.
2. The product’s shutter button is malfunctioning.
Solution
Updating the firmware of the Osmo Pocket series product:
*Osmo Pocket 4 Series & Osmo Pocket 3 Firmware Update Method
*DJI Pocket 2 Firmware Update Method
*Osmo Pocket Firmware Update Method
If taking photos/recording videos still fails after changing or formatting the microSD card and after a firmware update, please contact DJI Support for help.
Osmo Action Series
Issue Description
Solution
Update the DJI Mimo app to the latest version, and restart the app. Then use a microSD card compatible with the Osmo Action series product. Go to “Specifications” on the Product Page of the DJI official website to learn about compatible microSD cards.
If the microSD card is compatible, please save the photos/videos already on the microSD card, format the microSD card, and insert it into the Osmo Action series product again.
* Formatting the microSD card using the DJI Mimo app:
Solution
Update the firmware of the Osmo Action series product:
Updating Osmo Action 6’s Firmware
Updating Osmo Action 5 Pro/Osmo Action 4/Osmo Action 3’s Firmware
Updating DJI Action 2’s Firmware
Updating Osmo Action’s Firmware
Osmo Mobile Series
Issue Description
3. The captured or recorded photos/videos cannot be saved.
1. There is an error with the DJI Mimo app.
2. There is an error with the Bluetooth connection.
Solution
1. Update the DJI Mimo app to the latest version.
2. Reset the Osmo Mobile series product's Bluetooth, and reconnect it.
* If possible, try to use a mobile device with a different operating system for connection (For example, use an iOS device if the mobile device used was an Android device or vice versa).
Resetting Bluetooth:
Osmo Mobile 3 and DJI OM 4/DJI OM 4 SE: Press the M Button, Shutter/Record Button, and Trigger simultaneously to reset the Bluetooth connection.
Osmo Mobile 6、Osmo Mobile SE、DJI OM 5:Press the Switch Button, Shutter/Record Button, and Trigger simultaneously to reset the Bluetooth connection.
There is an error with the device’s shutter button.
Solution
If the issue persists after restarting the Osmo Mobile series device, please contact DJI Support for help.
If the captured or recorded photos/videos cannot be saved:
The mobile device’s storage space is insufficient, or the app’s storage permission is not enabled.
Solution
Enable the DJI Mimo app’s storage permission on the mobile device, and clear space on your mobile device if space is insufficient.
