Using editor templates
1. Enter the editor homepage and download the desired template.
2. Different templates have different requirements regarding the number of imported photos or video clips. The number of imported pictures or video clips must not be less than or more than the limits required by the template. Otherwise, the template will not be available for usage.
3. After a video is generated, tap the clip, filter, volume, or other option at the bottom of the screen to edit the video.
4. If editing the clip generated by the template is required, please import it through the “Pro” option in the app.
Adding Music
1. Using the music in the music library
1) Select music and tap “Add” to enter the music library.
2) Download the desired music and add it.
ImportingLocal Music
1) Please import music from an iOS device following the on-screen instructions.
2) If an Android system is being used, place the music file in the device's local music library or file manager. Select “Import from Local Music” or “Import from File Manager” in the app.
DJI has purchased built-in fonts, templates, and background music in the DJI Fly and DJI Mimo editors. You can select your own desired music when editing.
It is not recommended to use your work for profit and commercial purposes. Otherwise, it may be considered copyright infringement. For details, please go to [Profile] - [Settings] - [DJI Terms Use] in the DJI Fly app and see “User Rights and Obligations.”
