Osmo Mobile Series
Osmo Mobile 8P
Refer to the video below to learn how to use the ActiveTrack feature with Osmo Mobile 8P:
Osmo Mobile 8
Refer to the video below to learn how to use the ActiveTrack feature with Osmo Mobile 8:
Osmo Mobile 7P/Osmo Mobile 7
Refer to the video below to learn how to use the ActiveTrack feature with Osmo Mobile 7P/Osmo Mobile 7:
Osmo Mobile 6/Osmo Mobile SE/DJI OM 5/Osmo Mobile 4 Series
Refer to the video below to learn how to use the ActiveTrack feature with Osmo Mobile 6/Osmo Mobile SE/DJI OM 5/Osmo Mobile 4 Series:
Osmo Pocket Series
Osmo Pocket 4P
Refer to the video below to learn how to use the ActiveTrack feature with Osmo Pocket 4P
Osmo Pocket 4
Osmo Pocket 3
Refer to the video below to learn how to use the ActiveTrack feature with Osmo Pocket 3
[Note] In Panorama, Low-Light Video, Slow Motion (1080P@8X/4K@4X), Timelapse, Motionlapse, and SpinShot modes, ActiveTrack is not supported.
DJI Pocket 2
The following instructions take DJI Pocket 2 as an example to introduce how to use the ActiveTrack function.
Using DJI Pocket 2 alone for ActiveTrack
1. Power on DJI Pocket 2 and place the subject in the center of the camera view.
2. Double-tap the subject on the screen. If the subject is a person, the gimbal and camera will automatically recognize the face and enter the FaceTrack mode. If the subject is an object, the gimbal will enter the ActiveTrack mode.
3. Press the Shutter button to start tracking, and press the Function button to exit ActiveTrack.
Using with the DJI Mimo App for ActiveTrack
1. Connect to a mobile device through a smartphone adapter and launch the DJI Mimo app.
2. On the left side of the camera screen, you can set video parameters (video resolution and frame rate) and choose whether to enable Glamour Effects.
3. In the camera view, drag a box on the screen and a green box will appear around the shooting subject, which indicates that the recognition is successful.
4. Tap the Shutter button to start shooting. To exit ActiveTrack, press the Function button on the DJI Pocket 2 or tap X in the green box on the screen.
When using the ActiveTrack function, if issues such as inability to recognize the tracking target and tracking target loss occur, you can troubleshoot by referring to FAQ about ActiveTrack with Handheld Products.
Click Here to watch the video.
