The footage records by Osmo Mobile series products are stored in the mobile phones, please view them in the local album.
Osmo Nano
Transfer to a microSD Card
1. Attach the camera to the Vision Dock with the lens facing forward.
2. Swipe down from the top of the camera view, swipe left to enter the storage page, then tap Export to SD card.
3. When the message "Export files from internal storage to SD card?" appears, tap Confirm and wait for the export to finish.
Transfer to a Phone
Open the DJI Mimo app and connect the phone to the camera. Tap Album or the Camera icon > Playback to download footage.
1. Download one file: Tap the file to open its details page, then tap the Download icon in the top-right corner to download the file.
2. Download multiple files: On the thumbnail page, tap Select in the top-right corner, choose the files, then tap Download in the bottom-right corner.
Transfer to a Computer
1. Connect the camera to the computer
(1) Power on the camera and attach the camera to the Vision Dock with the lens facing forward.
(2) Use the provided data cable to connect the camera to the computer.
2. Select the transfer option on the camera
(1) After the camera is connected, the transfer options appear on the camera screen.
(2) Select the option that matches the storage location. For instance, to export footage from the built-in storage, tap File Transfer: Internal Storage.
3. Access the camera storage on the computer and export footage
Windows:
(1) On the computer, open This PC. A drive labeled Osmo Nano will appear.
(2) Double-click the Osmo Nano drive, open DCIM > DJI 001, select the photos or videos you want to export, and copy them to a local folder on your computer.
Note: If the camera cannot automatically recognize the connected device, open the camera's control center, tap Settings > USB mode, and reconnect the camera.
MacOS:
(1) Once connected, the "Allow accessories to connect?" message appears on the computer desktop. Click Allow.
(2) A camera icon appears on the desktop. If it does not appear, open the camera storage in Finder.
(3) Double-click the camera icon, open DCIM > DJI 001, select the photos or videos you want to export, and copy them to a local folder on your computer.
Osmo 360
Transfer to a Phone
Turn on Wi-Fi and Bluetooth on the phone. Open the DJI Mimo app and connect the phone to the camera. Tap Album or the Camera icon > Playback to download footage.
After the camera is connected, the transfer options appear on the camera screen. Tap File Transfer: USB.
Windows
(1) On the computer, open This PC. A drive labeled Osmo 360 will appear.
(2) Double-click the Osmo 360 drive, open the DCIM > DJI 001 folder, select the photos and videos that you want to export, and copy them to a local folder on your computer.
Note: Panoramic videos are saved in OSV format. Each panoramic video also includes an LRF proxy file.
macOS
Osmo Action Series
Support situation
Export Method
Osmo Action 6
Osmo Action 5 Pro
Osmo Action 4
Osmo Action 3
DJI Action 2
Via DJI Mimo
Supported
Supported
Supported
Supported
Supported
Supported
Via Computer
Supported
Supported
Supported
Supported
Supported
Supported
Via OTG connection
Supported
Supported
Supported
Supported
Not Supported
Not Supported
Export to a Phone
Method 1: Export via the DJI Mimo app
Applicable products: Osmo Action 6, Osmo Action 5 Pro, Osmo Action 4, Osmo Action 3, DJI Action 2, Osmo Action.
Method 2: Export to a phone or tablet via the OTG connection
Applicable products: Osmo Action 6, Osmo Action 5 Pro, Osmo Action 4, Osmo Action 3.
Please refer to How do I connect Osmo Action Series/Osmo Pocket Series to mobile phones via OTG Connection using the OTG function to learn how to export clips via the OTG function.
Export to a computer
Method 1: Device and computer connection export
Osmo Action 6
Osmo Action 5 Pro
 The steps below are for reference. Interfaces may vary by product and firmware version.
(1) Power on the camera and connect it to the computer using the provided cable. For DJI Action 2, connect the USB-C cable to the USB-C port on the front touchscreen module or the port on the Power Module.
(2) Some card readers may change SD card file attributes, which can cause recognition issues. We recommend connecting the camera to the computer with a data cable.
Windows
After the camera is connected, open This PC, double-click the camera drive, and open DCIM > DJI 001.
Note: If an SD card is inserted in the front touchscreen module or the power module of DJI Action 2, two drives will be displayed. The one labeled InternalStorage is the camera's built-in storage; the one labeled USB is SD card storage.
macOS
Method 2: Export using a card reader
Remove the SD card from the camera, insert it into a card reader, and connect the card reader to the computer to export footage.
Osmo Pocket Series
Support situation
Export Method
Osmo Pocket 4P
Osmo Pocket 4
Osmo Pocket 3
DJI Pocket 2
Via DJI Mimo(wired connection)
Supported
Supported
Supported
Supported
Supported
Via DJI Mimo(wireless connection)
Supported
Supported
Supported
Supported
Supported
Via Computer
Supported
Supported
Supported
Supported
Supported
Via OTG connection
Supported
Supported
Supported
Not Supported
Not Supported
• Wired connection: connecting to a mobile phone via the "Smartphone Adapter".
• Wireless connection: Connect your mobile phone via Bluetooth or Wi-Fi.
• To quickly export multiple files, we recommend using a card reader.
Export to a Phone
Method 1: Export via the DJI Mimo app (wired/wireless)
1. Download one file: Tap the file to enter the details page, then tap the Download icon in the top-right corner to download the file.
For more information, watch the video below:
Method 2: Via OTG connection
Applicable products: Osmo Pocket 4 Series, Osmo Pocket 3
Method 1: Export by connecting the camera to the computer
Notes:
(1) Make sure the smartphone adapter, the Osmo Pocket wireless module, and the Osmo Pocket 2 Do-It-All Handle are removed from the camera. Connect a USB-C cable to the port at the bottom of the camera.
(2) When connecting to a computer, due to signal limitations of the computer's USB port or the USB hub, some computers may not be able to read files on the SD card of Osmo Pocket 2 with the Do-It-All Handle attached. In this case, remove the Do-It-All Handle or use a card reader to export files.
Once connected, the "Connect to computer?" message appears on the camera screen. Tap Accept.
Windows
After the camera is connected, open This PC, double-click the camera drive, and open DCIM > DJI 001. Select the photos and videos that you want to export and copy them to a local folder on your computer.
macOS
