Applicable products: Osmo Action 3, Osmo Action 4, Osmo Action 5 Pro,Osmo Action 6.
Lens Protective Cover:
Disassembly: Rotate the lens protective cover counterclockwise.
Assembly: Rotate the lens protective cover clockwise.
USB-C Port Cover:
Osmo Action 6
Disassembly:
Assembly:
To open the USB-C port cover, press and hold the release button and push it towards the direction indicated by the release button.
Disassembly: Open the USB-C port cover and gently pull it off in the vertical direction of the camera.
Assembly: Align the USB-C port cover with the rotating shaft and gently press it to install it.
Battery Compartment Cover:
Osmo Action 6
Disassembly:
Assembly:
To open the battery compartment cover, press and hold the release button and push it towards the direction indicated by the release button.
Disassembly: Open the battery compartment cover and gently pull it off vertically from the camera.
Assembly: Align the battery compartment cover with the rotating shaft and gently press it to install it.
