Cables and Camera Ports
Product Model | Cable | Camera Port | Gimbal Port |
Ronin-S | Ronin-S Multi-Camera Control Cable (Multi) /MCC-Mulit | Multi Port | RSS Camera Control Port (8-pin port) |
Ronin-S Multi-Camera Control Cable (Mini USB) /MCC-Mini | Mini-USB Port | RSS Camera Control Port (USB-C) | |
Ronin-S Multi-Camera Control Cable (Type-C) /MCC-C | Type-C Port | RSS Camera Control Port (8-pin port) | |
Ronin-S Multi-Camera Control Cable (Type-B) /MCC-B | Micro-USB Port | RSS Camera Control Port (8-pin port) | |
Ronin-MX/S RSS Control Cable for Panasonic (RSS-P) | Remote Port | RSS Camera Control Port (8-pin port) | |
Ronin-S IR Control Cable /RSS-IR | Infrared Sensing Port | RSS Camera Control Port (8-pin port) | |
Ronin-SC | Ronin-SC Multi-Camera Control Cable (Multi-USB) | Multi Port | RSS Camera Control Port (USB-C) |
Ronin-SC Multi-Camera Control Cable (Type-C) | Type-C Port | RSS Camera Control Port (USB-C) | |
Ronin-SC RSS Control Cable for Fujifilm (RSS-F) | Remote Release Connector (φ2.5mm) | RSS Camera Control Port (USB-C) | |
Ronin-SC RSS Control Cable for Panasonic (RSS-P) | Remote Port | RSS Camera Control Port (USB-C) | |
Ronin-SC RSS Splitter | / | RSS Camera Control Port (USB-C) | |
DJI RS 2 DJI RSC 2 DJI RS 3 DJI RS 3 Pro DJI RS 3 Mini DJI RS 4 Pro DJI RS 4 | DJI R Multi-Camera Control Cable (USB-C) | Type-C Port | RSS Camera Control Port (USB-C) |
DJI R Multi-Camera Control Cable (Sony Multi) | Multi Port | RSS Camera Control Port (USB-C) | |
DJI R Multi-Camera Control Cable (Micro-USB) | Micro-USB Port | RSS Camera Control Port (USB-C) | |
DJI R Multi-Camera Control Cable (Mini-USB) | Mini-USB Port | RSS Camera Control Port (USB-C) | |
DJI R RSS Control Cable for Fujifilm | Remote Release Connector (φ2.5mm) | RSS Camera Control Port (USB-C) | |
DJI R RSS Control Cable for Panasonic (RSS-P) | Remote Port | RSS Camera Control Port (USB-C) | |
DJI RS 4 Mini/DJI RS 5 | DJI R Multi-Camera Control Cable (USB-C) | Type-C Port | RSS Camera Control Port (USB-C) |
Purchasing Cables
Please choose the cable as required:
DJI RS Series Camera Control Cable
Applicable Products: DJI RS 2, DJI RSC 2, DJI RS 3, DJI RS 3 Pro, DJI RS 3 Mini, DJI RS 4 Pro, DJI RS 4, DJI RS 4 Mini, DJI RS 5
The DJI R Multi-Camera Control Cable (USB-C) connects a camera with a USB-C port to the camera control port on DJI RS series stabilizers for camera control. Please visit the Ronin Series Compatibility Search to see supported camera models and functions. It also connects the DJI Ronin Focus Motor with DJI RS series stabilizers for power supply and communication.
The DJI R Multi-Camera Control Cable (Sony Multi) connects a Sony camera to the camera control port on DJI RS 2/DJI RSC 2/DJI RS 3/DJI RS 3 Pro for camera control.
The DJI R Multi-Camera Control Cable (Micro-USB) connects a camera with a Micro-USB port to the camera control port on DJI RS 2/DJI RSC 2/DJI RS 3/DJI RS 3 Pro for camera control.
Applicable Products: DJI RS 2, DJI RSC 2, DJI RS 3, & DJI RS 3 Pro, DJI RS 3 Mini, DJI RS 4 Pro, DJI RS 4, DJI RS 4 Mini
The DJI R Multi-Camera Control Cable (Mini-USB) connects a camera with a Mini-USB port to the camera control port on DJI RS series stabilizers for camera control.
The DJI R RSS Control Cable for Fujifilm connects a Fujifilm camera to the camera control port on DJI RS 2/DJI RSC 2/DJI RS 3/DJI RS 3 Pro for camera control.
The DJI R RSS Control Cable for Panasonic connects a Panasonic camera to the camera control port on DJI RS 2/DJI RSC 2/DJI RS 3/DJI RS 3 Pro for camera control.
Applicable Products: Ronin-S
Use the Multi-Camera Control Cable (Multi-USB) to connect your Sony camera to the Ronin-S Camera Control Port. Shutter, recording, and auto focus can be controlled through the camera control button of the gimbal. The optical zoom can be controlled through the Focus Wheel (only supported for lenses with built-in power zoom, such as the Sony E PZ 18-105 mm F4 G OSS. For other lenses, the Focus Wheel will control digital zoom. Digital zoom must be enabled in the camera settings.)
In order to control your camera with the Ronin-S Camera Control Button, use the Multi-Camera Control Cable (Mini USB) to connect your camera and the Ronin-S Camera Control Port.
The Multi-Camera Control Cable (Type-C) connects a camera with a Type-C port to the Camera Control Port (RSS Port) of the Ronin-S, giving it's Camera Control Button access to functions like photo taking, parameter configuration, and more.
The Multi-Camera Control Cable (Type-B) connects a camera with a Type-B port to the Camera Control Port (RSS Port) of the Ronin-S, giving it's Camera Control Button access to functions like photo taking, parameter configuration, and more.
Applicable Products: Ronin-MX and Ronin-S
Use the Ronin-MX/S RSS Control Cable for Panasonic to connect your Panasonic GH3 or GH4 and the Ronin-S Camera Control Port to control your camera. To use autofocus on the camera, press halfway down on the gimbal’s camera control button. It is also used to connect the Ronin-MX Remote Start/Stop Camera Port to Panasonic camera
This RSS IR Control Cable can be used with cameras that feature an infrared receiver. Insert one end of this cable into the Camera Control Port (RSS Port) of the Ronin-S, and adjust the cable so its IR diode is pointed to the camera's IR receiver. A successful connection will enable camera control via the Ronin-S Camera Control Button, giving you access to functions like video recording, photo taking, and more.
Ronin-SC Camera Control Cable
Applicable Products: Ronin-SC
The Ronin-SC Multi-Camera Control Cable (Multi-USB) connects the camera control port of Ronin-SC to the MultiPort on a Sony camera to fully control the camera.
The Ronin-SC Multi-Camera Control Cable (Type-C) connects a camera with a Type-C port to the Camera Control Port of Ronin-SC for camera control.
The cable enables Ronin-SC to control of Fujifilm cameras to record videos, take photos, and enable autofocus.
The Ronin-SC RSS Control Cable for Panasonic connects the camera control port of Ronin-SC to a Panasonic camera (GH3/GH4) for camera control.
The Ronin-SC RSS Splitter enables both camera control and power to the Ronin-SC Focus Motor simultaneously by providing a Type-C port.
