Log Upload Via DJI Fly app
Please refer to the following tutorial to learn about the "Log Upload":
1. Choose「Service > Log Upload」to enter the log upload page.
2. Select the date of Occurrence, and then select the desired "Flight Record" and "App Log". (It is recommended to select all flight records)
3. Fill in the issue description, specifying when the issue occurred, how it occurred, and what the outcomes were.
4. If there are any relevant screenshots or screen recordings related to the issue, please upload them together.
[Tips]
① The maximum size for pictures or videos should not exceed 500MB.
② The sizes of flight records, simplified flight controller data, and App Log are unlimited.
5. After completing all the content, please tap the "Submit" button to upload.
6. After uploading successfully, please take a screenshot or photo of the successful submission page and contact DJI Support for further assistance.
Log Upload Via DJI Mimo app
1. Go to「Profile > Contact Us > Log Upload」to enter the log upload interface.
2. Then input the related information and tap “Submit”. “Uploading Log” will be shown in the app and the QR code will be generated after upload.
3. After uploading successfully, please take a screenshot or photo of the successful submission page and contact DJI Support for further assistance.
Exporting App log files from an Android device
1. Connect an Android device to a computer using a USB cable. The “USB” connection mode will appear on the mobile phone. Select “Transfer files”.
2. Double click “My Computer”, and then click the mobile phone icon and go to internal storage.
3. Find the file path for logs of the corresponding app as required.
APP
File Path
DJI GO
DJI\dji.pilot\LOG
DJI GO 4
\DJI\dji.go.v4\LOG
DJI Mimo
Android:
SD Card/Android/data/dji.mimo/files/LOG(Pack the entire folder)
Internal storage/Android/data/dji.mimo/files/LOG
iOS:
DJI Mimo LOG:/Documents/Logs and /Documents/sdk;(Pack the entire folder)
Crash LOG:iTools---Toolbox---Crash Log—DJIMimo.xxxxxxx.ips
DJI Fly
DJI Fly App V1.4.12 and later versions:
APP log: internal storage/android/data/dji.go.v5/files/LOG
DJI Fly App version prior to V1.4.12:
\DJI\dji.go.v5\LOG
4. Please select the corresponding log file folder to export. After selection, please copy the entire file folder (Take DJI Fly App as an example here.)
5. Find the path: internal storage/android/data/dji.go.v5/files/LOG
6. please copy the entire file folder.
7. Paste the copied file folder to the desktop and zip it.
8. Send the zipped file back to DJI Support.
Exporting App log files from an iOS device
1. Download “iTunes” on your computer. Launch the software.
2. Connect the iOS device to the computer and tap “Trust” on the iPhone to authorize the computer to access your mobile phone.
3. In “iTunes”, tap the mobile device icon in the top-left corner, and skip to the iPhone page.
4. Select “File Sharing” in the left panel and go to the app file sharing page.
5. Select the corresponding app as required. Select the “Logs” file folder and tap “Save” at the bottom of the right window. (Take the DJI Fly App as an example here.)
7. Save the selected file folder to the desktop.
There is a major difference between MacOS Catalina (MacOS 10.15), macOS Big Sur (MacOS 11), and MacOS 12 computer systems and the MacOS version when the Apple device is connected to export files in the app. If your computer is MacOS Catalina, macOS Big Sur, and MacOS 12 series system, please follow the below steps to export the App Log:
1. Connect an iPhone or iPad to your computer using a USB cable.
2. Open “Finder” and select your device in “Finder”.
3. Tap “File” tag to view the list of apps that can share files. If “File” cannot be found, this indicates that the device has no app that can be used for file sharing.
4. Tap the triangle near the app to check the file to be shared.
5. Select the Log file to copy.
6. Drag the file to the computer desktop. Use the “Finder” to copy the file to the computer desktop.
7. Then, compress the entire file folder and send the entire package to DJI Support. (How to compress files on Mac: Tap and hold the Control key or double tap the button. Then, select “Compress” from the shortcut menu. The compression file name is changed to the initial original item name with the extension name “.zip”.)
