Applicable Scenarios
Suitable for scenarios that require recording multiple audio sources simultaneously, this type of multi-channel recording device has the advantage of being able to capture multiple audio sources at the same time, providing independent audio tracks for convenient post-editing and mixing.
Here are some typical application scenarios:
Group Interviews: When conducting group interviews, you can provide each interviewee with a microphone to ensure that everyone's voice is clearly recorded.
Small Meetings or Seminars: For small meetings or seminars, microphones can be provided separately for speakers and moderators to clearly record the entire meeting process.
Education and Training: In classroom or training environments, teachers and students can use microphones to record course content and interactive discussions.
Usage Guide
Use two sets of DJI Mic series (2 TX + 1 RX + Charging Case) on a mobile phone at the same time
1. Android device + USB-C to 3.5mm TRS (female) adapter cable + 3.5mm TRRS adapter (male) Y-splitter microphone monitoring adapter + 3.5mm to 3.5mm TRS Y-splitter cable + DJI Mic series RX*2.
2. iOS device + Lightning to 3.5mm TRS (female) adapter cable + 3.5mm TRRS adapter (male) Y-splitter microphone monitoring adapter + 3.5mm to 3.5mm TRS Y-splitter cable + DJI Mic series RX*2.
Use two sets of DJI Mic series (2 TX + 1 RX + Charging Case) on a camera at the same time
DJI Mic series RX*2 + 3.5mm to 3.5mm TRS Y-splitter cable + camera.
Use two sets of DJI Mic series (2 TX + 1 RX + Charging Case) on a computer at the same time.
1. If your computer has a dedicated 3.5mm microphone jack, use it as follows:
2. If the computer only has one 3.5 mm port, which is a headset jack, use it as follows:
3. If your computer does not have a 3.5mm microphone jack, you need to purchase a USB sound card separately. According to the type of 3.5mm port on the sound card, refer to the two methods mentioned above and choose the appropriate solution.
Purchase Plan
If you need to use several transmitters at the same time, you can refer to the purchase options below and click to enter the DJI Official Store for purchase:
1. DJI Mic 3
Natively supports 1 RX + 4 TX usage.
It is not recommended to use 1 RX + 8 TX, as using them at too close a distance may cause interference.
2. DJI Mic Mini 2S
1 RX + 3 TX Purchase Combo: Purchase DJI Mic Mini 2S (2 TX + 1 RX + Charging Case) + DJI Mic Mini (1 TX) / DJI Mic Mini 2 (1 TX) / DJI Mic Mini 2S (1 TX)
1 RX + 4 TX Purchase Combo: Purchase two sets of DJI Mic Mini 2S (2 TX + 1 RX + Charging Case) or DJI Mic Mini 2S (2 TX + 1 RX + Charging Case) + 2 DJI Mic Mini (1 TX) / DJI Mic Mini 2 (1 TX) / DJI Mic Mini 2S (1 TX).
3. DJI Mic Mini 2
1 RX + 3 TX purchase bundle: Purchase DJI Mic Mini 2 (2 TX + 1 RX + Charging Case) + DJI Mic (1 TX + 1 RX) / DJI Mic 2 (1 TX + 1 RX) / DJI Mic Mini 2 (1 TX + 1 RX)
1 RX + 4 TX purchase bundle: Purchase two sets of DJI Mic Mini 2 (2 TX + 1 RX + Charging Case).
4. DJI Mic Mini
1 RX + 3 TX purchase bundle: Purchase DJI Mic Mini 2 (2 TX + 1 RX + Charging Case) + DJI Mic (1 TX + 1 RX) / DJI Mic 2 (1 TX + 1 RX) / DJI Mic Mini (1 TX + 1 RX)
1 RX + 4 TX purchase bundle: Purchase two sets of DJI Mic Mini (2 TX + 1 RX + Charging Case).
5. DJI Mic 2
1 RX + 3 TX purchase bundle: Purchase DJI Mic 2 (2 TX + 1 RX + Charging Case) + DJI Mic (1 TX + 1 RX) / DJI Mic 2 (1 TX + 1 RX)
1 RX + 4 TX purchase bundle: Purchase two sets of DJI Mic 2 (2 TX + 1 RX + Charging Case).
6. DJI Mic
1 RX + 3 TX purchase bundle: Purchase DJI Mic (2 TX + 1 RX + Charging Case) + DJI Mic (1 TX + 1 RX) / DJI Mic 2 (1 TX + 1 RX)
1 RX + 4 TX purchase bundle: Purchase two sets of DJI Mic (2 TX + 1 RX + Charging Case).
FAQ
When using 1 RX + 3 or 4 TX, is stereo recording still supported?
Since stereo is generated from two channels, using 4 TX at this point will result in the sound from 2 TX being output as one channel, and it is not possible to fully separate the audio recording from the TX. Additionally, if you use a mobile phone, most adapter cables only support mono audio; even if you set it to stereo, it will have no effect. Therefore, it is recommended to use mono audio in this scenario.
Is it possible to achieve 1 RX + 4 TX with the mobile receiver?
Since the mobile receiver connects to the device via the Type-C port for audio transmission, most Type-C splitter adapters on the market feature one data transfer port and one charging port. Additionally, the mobile receiver requires power supply from an external device. When connected simultaneously, there may be issues such as insufficient power supply or abnormal audio transmission. Therefore, the mobile receiver does not support connecting 4 TX simultaneously.
