Step 1: Click to open the Ronin Series Compatibility Search page.
Step 2: Select the specified gimbal.
Select the specified single-handed DJI Ronin gimbal to view compatible cameras.
Step 3: Select the specified camera from the camera list.
Step 4: View the compatibility information.
Assume that you want to use Sony A7M3 with DJI RS 3 Pro. The following figure shows how to select a multi-camera control cable.
1. Connect to the Bluetooth shutter to control the camera to shoot photos, start/stop recording video, trigger auto focus, and use with the Ronin image transmitter.
2. Connect to the Multi-Camera Control Cable (USB-C) to start/stop recording video, trigger auto focus, pull focus electronically, and control the aperture, shutter, and ISO.
3. Connect to the Sony-Multi Camera Control Cable to control the camera to shoot photos, start/stop recording video, trigger auto focus, zoom, and use with the Ronin image transmitter.
4. Click on Setup Method at the bottom of the column to view how to set up the camera to use the preceding features.
If the camera model you are using is not in the list of compatible cameras, you can click "Request for your model" in the lower-right corner of the page. Then, enter the camera make and model and the lens make and model, and select your gimbal model.
The compatibility information on this page is the latest. If you have any other questions, please contact DJI Support for assistance.
