Error Code | Error Message Icon | Solution |
ERR23 | The display of the DJI Power indicates "ERR23", and the DJI Home app prompts "AC output port short circuit". | 1. There is an issue with the appliance connected to the AC output port. Please replace it with another appliance to check if the new one functions properly. |
ERR84 | The display of the DJI Power indicates "ERR84""ERR85",, and the DJI Home app prompts "SDC output error". | 1. Restart the device. |
ERR24 | The display of the DJI Power indicates "ERR24""ERR31""ERR33""ERR34" "ERR61" and the DJI Home app prompts "Device overheated". | 1. If the current firmware version of the power station is not the latest, please update to the latest. |
ERR30 | The display of the DJI Power indicates "ERR30", and the DJI Home app prompts "Temperature sensor error". | 1. Press and hold the power button to turn off the device, wait 30 minutes, and then press and hold the power button again to turn it back on. |
ERR22 | The display of the DJI Power indicates "ERR22", and the DJI Home app prompts "AC output overloaded". | 1. Remove any appliances that exceed the maximum continuous output power (e.g., for DJI Power 1000, the connected appliance should not exceed 2200W, which is its maximum continuous output). |
ERR80 | The display of the DJI Power indicates "ERR80""ERR81""ERR82""ERR83" and the DJI Home app prompts "SDC port function error". | 1.Connect the power supply to the current accessory. Connect the power station to DJI Assistant 2 (Power Series) or to the Home app (excluding DJI Power 500) to update to the latest firmware. 2. Reconnect the accessory on the SDC port. |
ERR92 | The display of the DJI Power indicates "ERR92""ERR93", and the DJI Home app prompts "Error in charger plugged into SDC port". | 1.Connect the power supply to the current accessory. Connect the power station to DJI Assistant 2 (Power Series) or to the Home app (excluding DJI Power 500) to update to the latest firmware. 2. Reconnect the accessory on the SDC port. 3. Restart the power station. 4. If multiple restarts cannot resolve the issue, please contact DJI Support. |
ERR86 | The display of the DJI Power indicates "ERR86""ERR87", and the DJI Home app prompts "SDC hardware error" | SDC hardware error,please contact DJI Support and send it back for inspection. |
ERR36 | The display of the DJI Power indicates "ERR36", and the DJI Home app prompts "Battery cell voltage too low". | 1.Charge the power station using slow charging mode until it is 100% FULL, press and hold the power button to turn off the power, and let it stand for 24 hours. |
ERR88 | The display of the DJI Power indicates "ERR88""ERR89", and the DJI Home app prompts "DJI Intelligent Flight Battery overheated". | 1. Wait for the DJI aircraft battery to cool down before it automatically resumes charging. |
ERR41 | The display of the DJI Power indicates "ERR41"or "Battery power insufficient"? | 1. The current temperature of the battery cell is low. In low-temperature conditions, the activity of the chemical substances within the battery decreases, leading to a decline in battery performance. 4.Fully charge the power station until the screen displays "FULL", and then turn on the AC function again. |
ERR37 | The display of the DJI Power indicates "ERR37", and the DJI Home app prompts "Battery cell voltage too high". | 1.Check if the firmware version of the power station is the latest. If not, connect it to DJI Assistant 2 (Power Series) or to the Home app (excluding DJI Power 500) to update to the latest firmware. 2.Remove the charging cable and all connected appliances from the power station, turn off the power, and wait 15 minutes before turning it back on. 3.If the issue persists after multiple attempts, please contact DJI Support. |
ERR26 | The display of the DJI Power indicates "ERR26", and the DJI Home app prompts "Hardware malfunction". |
ERR25 | The display of the DJI Power indicates "ERR25", and the DJI Home app prompts "Inverter Error Protection". | 1. Remove the charging cable and all connected appliances from the power station, press and hold the power button to turn off the power, and wait 30 seconds before pressing and holding the power button again to turn it back on. |
ERR10 | The display of the DJI Power indicates "ERR10", and the DJI Home app prompts "AC input voltage too high". | 1. The current connection of the power station to the grid power is unstable, resulting in low voltage. Please try again later and check if the error message disappears. |
ERR12 | The display of the DJI Power indicates "ERR12", and the DJI Home app prompts "AC input overloaded". | 1. Remove any appliances that exceed the maximum continuous output power (e.g., for DJI Power 1000, the connected appliance should not exceed 2200W, which is its maximum continuous output). |
ERR14 | The display of the DJI Power indicates "ERR14", and the DJI Home app prompts "AC input under-frequency". | 1.When the ac frequency of the power station differsfrom the frequency of the power grid (for example, when usingthe device indifferent regions), only recharging is supported and the power station cannot charge external devices. In this case, the screen will display an errorcode (ERR13 or ERR14). Pressand hold the AC button for more than 10 seconds to switch the frequency and resume normal use. |
ERR13 | The display of the DJI Power indicates "ERR13", and the DJI Home app prompts "AC input over-frequency". | 1.When the ac frequency of the power station differsfrom the frequency of the power grid (for example, when usingthe device indifferent regions), only recharging is supported and the power station cannot charge external devices. In this case, the screen will display an errorcode (ERR13 or ERR14). Pressand hold the AC button for more than 10 seconds to switch the frequency and resume normal use. |
ERR11 | The display of the DJI Power indicates "ERR11", and the DJI Home app prompts "AC input voltage too low". | 1. The current connection of the power station to the grid power is unstable, resulting in low voltage. Please try again later and check if the error message disappears. |
ERR4 | The display of the DJI Power indicates "ERR4", and the DJI Home app prompts "Battery management system (BMS) software version error". | 1. Check if the firmware version of the power station is the latest. If not, connect it to DJI Assistant 2 (Power Series) or to the Home app (excluding DJI Power 500) to update to the latest firmware. |
ERR19 | The display of the DJI Power indicates "ERR19", and the DJI Home app prompts "DC output port short circuit". | 1. Please remove the charging cable and all loads from the device, then power off it and wait for 30 seconds before restarting. |
ERR17 | The display of the DJI Power indicates "ERR17", and the DJI Home app prompts "DC output port overcurrent". | 1. Please remove the charging cable and all loads from the device, then power off it and wait for 30 seconds before restarting. |
ERR15 | The display of the DJI Power indicates "ERR15", and the DJI Home app prompts "DC output voltage too high". | 1. Please remove the charging cable and all loads from the device, then power off it and wait for 30 seconds before restarting. |
ERR18 | The display of the DJI Power indicates "ERR18", and the DJI Home app prompts "DC output overloaded". | 1. Please remove the charging cable and all loads from the device, then power off it and wait for 30 seconds before restarting. |
ERR16 | The display of the DJI Power indicates "ERR16", and the DJI Home app prompts "BUS output undervoltage protection". | 1. Ensure the power supply is above 50%, turn off the power, wait for 3 minutes, and then restart. |
ERR20 | The display of the DJI Power indicates "ERR20", and the DJI Home app prompts "DC input voltage too high". | 1. Please remove the charging cable and all loads from the device, then power off it and wait for 30 seconds before restarting. |
ERR21 | The display of the DJI Power indicates "ERR21", and the DJI Home app prompts "DC output voltage too low". | 1. Please remove the charging cable and all loads from the device, then power off it and wait for 30 seconds before restarting. |
ERR91 | The display of the DJI Power indicates "ERR91", and the DJI Home app prompts "SDC Lite port does not support connecting to expansion battery". | DJI Power Expansion Battery 2000 cannot be connected to the SDC Lite. Instead, it must be inserted into the SDC. |
ERR90 | The display of the DJI Power indicates "ERR90", and the DJI Home app prompts "Device not supported by SDC or SDC 1 port". | 1.If the wireless module is not supported on the SDC port, please insert it into the SDC Lite port for use. 2.If it is another SDC accessory, please check the compatibility between the SDC accessory and the power station. 3.If the issue persists after multiple attempts, please contact DJI Support. |
ERR63 | The display of the DJI Power indicates "ERR63", and the DJI Home app prompts "Charging overcurrent". | 1. Remove any appliances that exceed the maximum continuous output power (e.g., for DJI Power 1000, the connected appliance should not exceed 2200W, which is its maximum continuous output). |
ERR45 | The display of the DJI Power indicates "ERR45", and the DJI Home app prompts "Battery malfunction". | The battery is faulty,Please contact the DJI customer support team and return it for inspection. |
ERR40 | The display of the DJI Power indicates "ERR40", and the DJI Home app prompts "Battery cell voltage unstable". | 1. Restart the device. |
ERR35 | The display of the DJI Power indicates "ERR35", and the DJI Home app prompts "Battery cell voltage too high". | 1.Remove the charging cable and all connected appliances from the power station, turn off the power, and wait 15 minutes before turning it back on. |
ERR68 | The display of the DJI Power indicates "ERR68", and the DJI Home app prompts "Abnormal fan speed". | 1. Power off the power station by pressing and holding the power button. Then press and hold the button again to power it on after 30 seconds. |
ERR2 | The display of the DJI Power indicates "ERR2", and the DJI Home app prompts "Software version error". | 1.Check if the firmware version of the power station is the latest. If not, connect it to DJI Assistant 2 (Power Series) or to the Home app (excluding DJI Power 500) to update to the latest firmware. |
ERR43 | The display of the DJI Power indicates "ERR43", and the DJI Home app prompts "Device overcurrent". | 1. Remove the charging cable and all connected appliances from the power station. |
ERR42 | The display of the DJI Power indicates "ERR42", and the DJI Home app prompts "Device has water damage". | The equipment is suspected of water ingress, please contact DJI Support and send it back for inspection. |
ERR44 | The display of the DJI Power indicates "ERR44", and the DJI Home app prompts "Output port short circuit". | 1. Restart the device. |
ERR62 | The display of the DJI Power indicates "ERR62", and the DJI Home app prompts "Output overloaded". | 1. Remove any appliances that exceed the maximum continuous output power (e.g., for DJI Power 1000, the connected appliance should not exceed 2200W, which is its maximum continuous output). |
ERR67 | The display of the DJI Power indicates "ERR67", and the DJI Home app prompts "Communication error between main board and battery management system (BMS)". | 1.Check if the firmware version of the power station is the latest. If not, connect it to DJI Assistant 2 (Power Series) or to the Home app (excluding DJI Power 500) to update to the latest firmware. 2. Power off the power station by pressing and holding the power button. Then press and hold the button again to power it on after 30 seconds. |
ERR65 | The display of the DJI Power indicates "ERR65", and the DJI Home app prompts "Communication error between main board and SDC port". | 1.Check if the firmware version of the power station is the latest. If not, connect it to DJI Assistant 2 (Power Series) or to the Home app (excluding DJI Power 500) to update to the latest firmware. 2. Power off the power station by pressing and holding the power button. Then press and hold the button again to power it on after 30 seconds. |
ERR64 | The display of the DJI Power indicates "ERR64", and the DJI Home app prompts "Communication error between main board and USB port". | 1.Check if the firmware version of the power station is the latest. If not, connect it to DJI Assistant 2 (Power Series) or to the Home app (excluding DJI Power 500) to update to the latest firmware. 2. Power off the power station by pressing and holding the power button. Then press and hold the button again to power it on after 30 seconds. |
ERR3 | The display of the DJI Power indicates "ERR3", and the DJI Home app prompts "Communication error between main board and inverter". | 1. Power off the power station by pressing and holding the power button. Then press and hold the button again to power it on after 30 seconds. |
ERR3 | The display of the DJI Power indicates "ERR3", and the DJI Home app prompts "Software version error in accessories plugged into SDC port". | 1. Connect the power station with the accessory, and connect the power station to DJI Assistant 2 (Power Series) to update to the latest firmware. |
ERR32 | The display of the DJI Power indicates "ERR32", and the DJI Home app prompts "Device temperature too low". | 1. The current temperature of the battery cell is low. In low-temperature conditions, the activity of the chemical substances within the battery decreases, leading to a decline in battery performance. |
ERR27 | DJI Power Series products indicate "ERR27" "Grid waveform anomaly or AC side anomaly." | Current grid fluctuations have been detected. To ensure device safety, please temporarily turn off high-power electrical appliances or wait for a while before charging the power supply. If multiple attempts still cannot resolve the issue, please contact DJI Support. |
ERR66 | The display of the DJI Power indicates "ERR66", and the DJI Home app prompts "Communication error between main board and inverter". | 1. If the power supply is currently connected to the mains, disconnect it from the mains power. |
/ | DJI HOME APP indicates "Suspected power outage. Check household electrical network", | Detected suspected power outage or device connection anomaly. If it's not a power outage, please ensure the device is properly connected and the home grid circuit is stable. |
/ | DJI HOME APP indicates "Device battery low. Charge in time" | The current power supply is low, please charge the power supply promptly to avoid affecting its functionality. |
ERR69 | The Display of the DJI Power indicates "ERR69", and the DJI Home app prompts "USB-C output error". | 1. Remove devices connected to the USB-C Port. 3.Cross-test with other USB-C appliances to check if they work properly. If they do, the current appliance may be faulty or incompatible with the power station. |
ERR70 | The display of the DJI Power indicates "ERR70", and the DJI Home app prompts "USB-A output error". | 1. Remove the connected device from the USB-A port. 3.Cross-test with other USB-C appliances to check if they work properly. If they do, the current appliance may be faulty or incompatible with the power station. |
ERR71 | The display of the DJI Power indicates "ERR71", and the DJI Home app prompts "Charging cable incompatible". | 1. Use the original Power Cable to avoid charging failure or safety issues caused by non-original cables. |
/ | DJI Power Series products display "Low Battery Alarm Active" | The current power supply is low, please charge the power supply promptly to avoid affecting its functionality. |
/ | DJI Power Series products display "Car battery low. Check battery health" | Car battery depletion detected. Please check the status of the car battery and address it promptly if abnormal. |
/ | DJI Power Series products display "Output power decreased. Charge promptly" | 1. The power supply has low battery. Please remove all electrical appliances from the power supply and charge it promptly. |
/ | DJI Power Series products display the message "Energy Saver mode unavailable. Power grid disconnected" | 1. The power device has detected a change in usage Scenario. Currently, to protect your power safety, ECO mode is paused. |
/ | DJI Power Series products display the message "Energy Saver mode can be resumed" | You can now re-enter ECO mode. Please ensure the AC power charging cable is correctly connected to the power grid and remains stable. Re-enable ECO mode to resume normal use. |
/ | DJI Power Series products prompt "Device temperature too low". | 1. Please use the product within the temperature range specified in the product User Manual: Operating ambient temperature: -10°C to 45°C, Charging ambient temperature: 0°C to 45°C. |
DJI Power Error Code Description and Solution
Applicable Products:DJI Power Auro 2000 Elite
Helpful?
Yes
No
Contact Us
- Online Customer Service
- Contact online customer service for immediate support.
- Contact Online Customer Service
