Currently, the DJI Mic 3/DJI Mic Mini 2S/DJI Mic Mini 2/DJI Mic Mini/DJI Mic 2 transmitter only supports direct Bluetooth connection with Osmo Action 6, Osmo Action 5 Pro, Osmo Action 4, Osmo Pocket 4, Osmo Pocket 3, Osmo Nano, Osmo 360, mobile phones, and computers equipped with Bluetooth functionality.
1. For Osmo Action 6, Osmo Action 5 Pro, Osmo Pocket 4, Osmo Pocket 3, Osmo Nano, Osmo 360, two transmitters can be connected.
2. Osmo Action 4 (only supports connecting one Transmitter) and mobile phones (can connect two Transmitters but only the first connected Transmitter can record audio).
3. It is not recommended to connect DJI Mic 3/DJI Mic 2/DJI Mic Mini 2S/DJI Mic Mini 2/DJI Mic Mini TX to a computer via Bluetooth mode, as the audio quality is inferior compared to connecting with a receiver.
💡[Tips]
1. When DJI Mic 3 is directly connected to a mobile device via Bluetooth, it supports voice tone presets, gain adjustment, noise cancellation, mute, low cut, 32-bit float internal recording, dual-file internal recording, and adaptive gain control. These functions take effect after being set via the DJI Mimo app or the receiver. When DJI Mic 2 is directly connected to a mobile device via Bluetooth, intelligent noise cancellation and internal recording cannot be enabled. When the transmitter of DJI Mic Mini 2S/DJI Mic Mini 2/DJI Mic Mini is directly connected to a mobile device via Bluetooth, intelligent noise cancellation can be enabled, but only the Strong level is available.
2.When the transmitter of DJI Mic Series is connected to a mobile device via Bluetooth, the audio quality is slightly lower comparing to using the receiver with an adapter. The receiver and adapter setup supports a 48 kHz sampling rate and 24-bit depth, while Bluetooth audio is limited to a maximum of 16 kHz and 16-bit, similar to Bluetooth headsets.
3.DJI Mic 3/DJI Mic 2/DJI Mic Mini 2S/DJI Mic Mini 2/DJI Mic Mini TX can theoretically connect to a computer via Bluetooth as long as the computer has Bluetooth functionality, but whether it can record sound should be verified through actual testing, as the recording sound quality is poor.
📖 Learn More: DJI Mic Series Mobile Phone Compatibility List
