DJI Mic 2 camera adapter is a specially designed hot shoe adapter for use with DJI Mic 2 and Sony cameras.
DJI Mic 2 connects to the camera via the camera adapter, allowing for digital audio recording and providing power to the DJI Mic 2 receiver. The camera adapter offers a more convenient installation method, and its utilization of digital audio effectively addresses the problem of electrical noise often encountered with Sony cameras.
If you use a Sony camera with DJI Mic 2 for recording, we recommend using the dedicated DJI Mic 2 camera adapter*.
* The Sony Hot Shoe Adapter cannot be used with DJI Mic 2.
Camera power supply: The hot shoe adapter carries the receiver, and the camera supplies a 73 mA electrical current to the hot shoe.
Folded: 22.2 x 33.1 x 23.0 (mm)
Unfolded: 22.2 x 33.1 x 38.8 (mm)
Weight: 0.012 kg
Using with a Camera
1. Remove the protective cover plate of the camera adapter.
2. After expanding the camera adapter, install it onto the expansion port of the DJI Mic 2 receiver.
3. Install the camera adapter to the camera hot shoe.
💡[Tips]
1. The DJI Mic 2 camera adapter is exclusively compatible with Sony cameras that support the Mi hot shoe. For specific compatible models, please consult the compatibility list
2. If the camera adapter is connected to the camera and a prompt indicates that the camera is not compatible, it may also indicate that the camera does not support Mi hot shoe, which leads to the inability to recognize the DJI Mic 2 camera adapter. In such cases, it is advised to utilize a 3.5 mm camera cable for connection instead.
Updating the Firmware
You can update the DJI Mic 2 camera adapter using the following methods:
1. Download the firmware update package for the receiver from the official DJI website Download page.
2. Once the receiver has been updated to the latest firmware version, proceed to install the DJI Mic 2 camera adapter with the receiver. Subsequently, the receiver will automatically recognize the DJI Mic 2 camera adapter and initiate the update process.
3. Upon displaying the message "Update successful" on the receiver, it indicates that the firmware update for the DJI Mic 2 camera adapter has been successfully finalized.
DJI Mic 2 Camera Adapter Compatibility List
Supported Camera Model | Digital Signal | Camera Power Supply |
ZV-E1 | √ | √ |
ZV-E10 | √ | √ |
ILCE-1 | √ | √ |
ILCE-9M3 | √ | √ |
ILCE-9M2 | √ | √ |
ILCE-7SM3 | √ | √ |
ILCE-7RM5 | √ | √ |
ILCE-7RM4A | √ | √ |
ILCE-7RM4 | √ | √ |
ILCE-7CR | √ | √ |
ILCE-7CM2 | √ | √ |
ILCE-7C | √ | √ |
ILCE-7M4 | √ | √ |
ILCE-6700 | √ | √ |
ILME-FX30 | √ | √ |
ILME-FX3 | √ | √ |
💡[Tips]
1. The DJI Mic 2 receiver (RX) does not support Power On/Off Camera Simultaneously when connected to the camera via the DJI Mic 2 Camera Adapter.
2. Control the receiver volume bar to bounce in the green and yellow and avoid hitting red to prevent overexposure.
FAQs
1. What are the differences between using the DJI Mic 2 camera adapter and using a 3.5 mm camera cable to connect to a Sony camera?
DJI Mic 2 connects to the camera via the camera adapter, allowing for digital audio recording and providing power to the receiver, while DJI Mic 2 connects to the camera using a 3.5 mm camera connection cable, enabling analog audio recording and achieving the "Powering on/off Camera Simultaneously" function.
The DJI Mic 2 camera adapter exclusively supports digital audio signals, whereas the Sony hot shoe facilitates the switching between analog and digital audio signals. Meanwhile, Sony's camera hot shoe adapter cannot be used with DJI Mic 2.
2. Can the DJI Mic 2 camera adapter be used with DJI Mic?
No.
3. When I connect DJI Mic 2 to my Sony camera using a DJI Mic 2 Camera Adapter instead of a 3.5 mm camera audio cable, the volume of the recorded audio varies. How do I address this issue?
Follow the Instructions on Recommended Gain for Camera Setup on DJI's official website to set the gain of the receiver and the camera to the recommended levels. With the recommended gain settings, the volume of recorded audio remains consistent regardless of whether a DJI Mic 2 Camera Adapter or a 3.5 mm camera audio cable is used.
DJI Mic 2 Camera Adapter features digital audio recording, where only the Transmitter Gain setting is effective. The Receiver Gain setting is not applied. If the audio volume is too low to meet your requirements, increase the value of Transmitter Gain or increase the gain in post-editing software.
4. Is DJI Mic 2 Camera Adapter compatible with Sony FX6?
No.
5. How long is the warranty period for DJI Mic 2 Camera Adapter?
DJI Mic 2 Camera Adapter has a 3-month warranty period.
6. What should I do if my camera does not recognize the DJI Mic 2 Camera Adapter?
1. Please check if your camera model is on the compatibility list; if not, the camera is not supported and therefore cannot be recognized. See the compatible models in the DJI Mic 2 Camera Adapter Compatibility List.
2. Please check if you have updated the firmware of the camera adapter. If the not, please performed a firmware update.
3. If the camera adapter still cannot be recognized by the camera after the update, please send the DJI Mic 2 camera adapter back to DJI for inspection.
7. What should I do if the camera cannot provide power to the receiver through the DJI Mic 2 Camera Adapter?
2. Please check if you updated the firmware of the camera adapter. If the not, please performed a firmware update.
3. If the camera still cannot charge the receiver through the adapter after the update, please send the DJI Mic 2 camera adapter back to DJI for inspection.
