DJI Goggles N3/DJI Goggles 3 can play videos up to 4K/60fps in the following formats:
1. MP4, MOV (video coding formats: H.264 and H.265; audio formats: AAC and PCM).
2. Panoramic video: sphere 2D panoramic video.
3. 3D video(Only DJI Goggles 3): Half-Side-by-Side (HSBS), Full-Side-by Side (FSBS), Half Over-Under (HOU), and Full Over-Under (FOU).
You can store videos in the DCIM\100MEDIA folder on the microSD card and then access the Album in the goggles to play the videos.
💡[Tips]
• If the microSD card is inserted into DJI Goggles N3/DJI Goggles 3, the content on the microSD card cannot be viewed when DJI Goggles N3/DJI Goggles 3 is connected to a computer. You can use a card reader or connect your drone (with the microSD card inserted) to a computer for file transfer.
• As DJI Goggles N3/DJI Goggles 3 does not come with a speaker, you will need to wear headphones with a Type-C port to enjoy audio. If you prefer using headphones with a 3.5 mm port, you will need an adapter.(Only USB-C headphones or headphone adapters with built-in DAC decoding are supported. If you hear no audio after connecting headphones, check if the headphones support DAC decoding.)
