Learn More: Aircraft Accessory Compatibility
Compatibility List
Notes: "√" indicates compatible, "×" is incompatible.
Model | DJI Lito 1 | DJI Lito X1 | DJI Avata 360 | DJI Neo 2 | DJI Mini 5 Pro | DJI Mavic 4 Pro | DJI Flip | DJI O4 Air Unit | DJI Air 3S | DJI Neo | DJI Avata 2 | DJI Avata | DJI Mini 4 Pro | DJI Mini 3 Pro | DJI Air 3 | DJI Mavic 3 Series | DJI FPV |
DJI Goggles N3 | × | × | √ | √ | × | × | × | √ | × | √ | √ | × | × | × | × | × | × |
DJI Goggles 3 | × | × | √ | √ | × | × | × | √ | × | √ | √ | × | √ | × | √ | × | × |
DJI Goggles Integra | × | × | × | × | × | × | × | √ | × | × | √ | √ | √ | √ | √ | √ | √ |
DJI FPV Goggles V2 | × | × | × | × | × | × | × | × | × | × | × | √ | × | × | × | × | √ |
DJI Goggles 2 | × | × | × | × | × | × | × | √ | × | × | √ | √ | √ | √ | √ | √ | √ |
Goggles | × | × | × | × | × | × | × | × | × | × | × | × | × | × | × | × | × |
Goggles RE | × | × | × | × | × | × | × | × | × | × | × | × | × | × | × | × | × |
DJI FPV Goggles | × | × | × | × | × | × | × | × | × | × | × | × | × | × | × | × | × |
DJI RC Motion 3 | × | × | √ | √ | × | × | × | × | × | √ | √ | × | √ | × | √ | × | × |
DJI RC Motion 2 | × | × | × | × | × | × | × | × | × | × | √ | √ | √ | √ | √ | √ | × |
DJI RC Motion | × | × | × | × | × | × | × | × | × | × | × | √ | × | × | × | × | √ |
DJI FPV Remote Controller 3 | × | × | √ | √ | × | × | × | √ | × | √ | √ | × | × | × | × | × | × |
DJI FPV Remote Controller 2 | × | × | × | × | × | × | × | √ | × | × | √ | √ | × | × | × | × | √ |
DJI FPV Remote Controller | × | × | × | × | × | × | × | × | × | × | × | × | × | × | × | × | × |
Function List
Drone | Goggles/Motion Controller | Firmware | Function |
DJI Mini 4 Pro | DJI Goggles 3 DJI RC Motion 3 | v01.00.0400 or above | 1. The Portrait mode, settings for gimbal parameter, manual focus, enhanced transmission and intelligent flight modes such as ActiveTrack, Waypoint Flight, MasterShots, or QuickShots are not supported. 2. Only the following shooting modes are supported: • Photo: Single shot (12MP resolution) • Video: Normal (4K/60fps, 1080p/60fps) 3. When using the remote controller as the control device (DJI RC 2/DJI RC-N2): • Only the goggles display image transmission. DJI Fly does not display image transmission. • The remote controller can control the recording function of the aircraft, but cannot control the recording function of the goggles. Enabling recording from the shortcut menu of the goggles will enable the aircraft and the goggles to record simultaneously. 4. When using the DJI RC Motion 3, head tracking is supported. 5. Obstacle Avoidance is supported (Brake or Bypass). |
DJI Goggles Integra DJI Goggles 2 DJI RC Motion 2 | v01.00.0300 or above | Only the following functions are supported, while the other intelligent modes are not supported. 1. Photo: Single shot (12MP resolution) 2. Video: Normal (4K/60fps, 1080p/60fps) 3. Obstacle avoidance actions are supported (brake/bypass). Disabling obstacle avoidance when a remote controller is used results in automatic deactivation of obstacle avoidance when switching to RC Motion 2 later. 💡Note: Zoom is not supported. | |
DJI Air 3 | DJI Goggles 3 DJI RC Motion 3 | v01.00.12.00 or above | 1. Camera switching, settings for gimbal parameter, manual focus, enhanced transmission and intelligent flight modes such as ActiveTrack, Waypoint Flight, MasterShots, or QuickShots are not supported. 2. Only the following shooting modes are supported: • Photo: Single shot (12MP resolution) • Video: Normal (4K/60fps, 1080p/60fps) 3. When using the remote controller as the control device (DJI RC 2/DJI RC-N2): • Only the goggles display image transmission. DJI Fly does not display image transmission. • The remote controller can control the recording function of the aircraft, but cannot control the recording function of the goggles. Enabling recording from the shortcut menu of the goggles will enable the aircraft and the goggles to record simultaneously. 4. When using the motion controller as the control device, head tracking is supported. 5. Obstacle Avoidance is supported (brake or bypass). |
DJI Goggles Integra DJI Goggles 2 DJI RC Motion 2 | v01.00.06.00 or above | Only the following functions are supported; all other intelligent functions are not supported. 1. Photo: Single shot (12MP resolution) 3. Obstacle Avoidance is supported (brake or bypass). Disabling obstacle avoidance when a remote controller is used results in automatic deactivation of obstacle avoidance when switching to RC Motion 2 later. Notes: Zoom is not supported. | |
DJI Mavic 3 Pro | DJI Goggles Integra DJI Goggles 2 DJI RC Motion 2 | v01.01.0100 or above | Only the following functions are supported. Other intelligent functions are not supported. • Disabling obstacle avoidance when a remote controller is used results in automatic deactivation of obstacle avoidance when switching to RC Motion 2 later. |
DJI Mavic 3 | DJI Goggles Integra DJI Goggles 2 DJI RC Motion 2 | v01.00.1100 or above | |
DJI Mavic 3 Classic | DJI Goggles Integra DJI Goggles 2 DJI RC Motion 2 | v01.00.0400 or above | |
DJI Mini 3 Pro | DJI Goggles Integra DJI Goggles 2 DJI RC Motion 2 | v01.00.06.00 or above | Only the following functions are supported. Other intelligent functions are not supported. 3. Obstacle Avoidance is supported (brake or bypass). • Disabling obstacle avoidance when a remote controller is used results in automatic deactivation of obstacle avoidance when switching to RC Motion 2 later. Note: Zoom is not supported. |
