Support Situation
When connected with devices such as DJI RS 5, DJI RS 4 Pro, DJI RS 4, and DJI RS 3 Pro, DJI SDR Transmission can be powered through the gimbal and enables Force Mobile, virtual joystick, gimbal recentering, and more functions.
💡[Tips]
1. Please note that when the DJI SDR Transmission Transmitter is connected to a stabilizer, the multi-camera control cable from the stabilizer's combo must be used;
2. ActiveTrack will not be available.
3. When the DJI SDR Transmission Transmitter is connected to a stabilizer via the adapter plate, a native vertical shooting setup is not supported.
Product
Notes
DJI RS 5
DJI RS 4 mini
DJI RS 4
Can realize Force Mobile, virtual joystick, and gimbal recenter functions. Make sure the stabilizer firmware is the latest (v01.03.0000 or above).
DJI RS 4 Pro
DJI RS 3 mini
DJI RS 3
Due to the insufficient port power output, DJI RS 3 cannot supply power to DJI SDR Transmission.Gimbal control cannot be achieved.
DJI RS 3 Pro
Can realize Force Mobile, virtual joystick, and gimbal recenter functions. Make sure the stabilizer firmware is the latest (v01.05.0000 or above).
DJI RS 2
Due to the insufficient port power output, DJI RS 2 cannot supply power to DJI SDR Transmission.Gimbal control cannot be achieved.
DJI RSC 2
Due to the insufficient port power output, DJI RSC 2 cannot supply power to DJI SDR Transmission.Gimbal control cannot be achieved.
DJI High-Bright Remote Monitor
DJI High-Bright Remote Monitor cannot be linked to the transmitter of DJI SDR Transmission directly, but it can be used for receiving videos from the HDMI Output Port on the receiver of DJI SDR Transmission.
DJI Transmission
DJI SDR Transmission devices cannot be linked to DJI Transmission devices.
DJI Ronin 4D
DJI Ronin 4D Video Transmitter cannot be linked to the receiver of DJI SDR Transmission directly, but it can output image signals to the receiver via HDMI port or SDI port.
DJI Focus Pro
DJI Inspire 3
It can output image signals to the transmitter of DJI SDR Transmission via HDMI port. Make sure the distance between the transmitter and the aircraft remote controller is more than one meter.
DJI Ronin 2
DJI Master Wheels 3-Axis
DJI Force Pro
Connection Guide
To use the transmitter with a camera and a stabilizer, follow the steps below to install and connect the devices:
1. Remove the TX gimbal mounting adapter plate from the packaging, install the adapter plate on the bottom of the transmitter, and tighten the screws.
2. Mount the transmitter to the camera mounting plate of DJI RS 4 Pro via the cold shoe on the adapter plate.
3. Use the dedicated camera control cable (USB-C, 30 cm) to connect the Video Transmission/LiDAR Range Finder Port (USB-C) of the gimbal and the USB-C Power and Gimbal Communication Port of the transmitter. Then the gimbal can supply power to the transmitter.
4. Connect the HDMI or SDI input port of the transmitter with the video signal port (HDMI or SDI port) of the camera using a transmission signal cable (HDMI or SDI cable).
5. Connect the transmitter to a mobile device via Wi-Fi, then open the DJI Ronin app for use.
