DJI Mavic Series
DJI Mavic 4 Pro Parallel Charging Hub
Compatible products: DJI Mavic 4 Pro
Blinking Pattern | Description |
Solid yellow | The charging hub is idle |
Pulses green | Charging the battery or accumulating power |
Solid green | All batteries fully charged or supplying power to external devices |
Blinks yellow | Temperature of the batteries/240W power adapter is too low or too high (no further operation needed) |
Solid red | Power supply error or battery error (remove and reinsert the batteries or unplug and plug in the charger) |
DJI Mavic 3 Series Battery Charging Hub
Compatible products: DJI Mavic 3 Pro, DJI Mavic 3 Pro Cine, DJI Mavic 3 Classic, DJI Mavic 3, DJI Mavic 3 Cine, DJI Mavic 3 Enterprise Series
Solid yellow | No battery is inserted into any port. |
Pulses green | The battery is charging. |
Solid green | All batteries are fully charged. |
Blinks yellow | Temperature of batteries is too low or too high (no further operation needed). |
Solid red | Power supply error or battery error (unplug and plug the batteries or charger to resume charging). |
Mavic 2 Battery Charging Hub
Compatible products: Mavic 2 Pro, Mavic 2 Zoom, Mavic 2 Enterprise Series
Mavic Pro Battery Charging Hub
Compatible products: Mavic Pro, Mavic Pro Platinum
Blinks yellow | The temperature of the batteries is too low or too high (no further operation needed). |
DJI Flip Series
DJI Flip Parallel Charging Hub
Compatible Product: DJI Flip
Charging Status
Status LEDs in an array blink quickly successively | The battery in the corresponding battery port is being charged using a USB PD charger. |
Status LEDs in an array blink slowly successively | The battery in the corresponding battery port is being charged using a normal charger. |
Status LEDs in an array are solid | The battery in the corresponding battery port is fully charged. |
All status LEDs blink in sequence | No battery is inserted |
Charging Logic
Charger Power | Charging sequence |
Charger Power <65 W | Charges in sequence from highest to lowest battery level. |
Charger Power ≥65 W | Charges two batteries simultaneously: First charges the battery with the second highest battery level until it matches the battery level with the highest charge, then fully charges both batteries together |
DJI Air Series
DJI Air 3 Series Battery Charging Hub
Compatible product: DJI Air 3S, DJI Air 3.
Solid yellow | The charging hub is idle. |
Pulses green | The charging hub is charging batteries or accumulating power. |
Solid green | All batteries are fully charged or are supplying power to external devices. |
Mavic Air 2 Battery Charging Hub
Compatible products: DJI Air 2S, Mavic Air 2.
Mavic Air Battery Charging Hub
Compatible product: Mavic Air
Solid green | Batteries are fully charged. |
DJI Neo Series
DJI Neo 2 Two-Way Charging Hub
Compatible products: DJI Neo 2.
DJI Neo Two-Way Charging Hub
Compatible products: DJI Neo.
💡 [Tip] Each battery port has its corresponding status LED array.
Status LEDs in an array blink quickly and successively. | The battery in the corresponding battery port is being charged using a Quick Charge charger. |
Status LEDs in an array blink slowly and successively | The battery in the corresponding battery port is being charged using a normal charger. |
Status LEDs in an array are solid. | The battery in the corresponding battery port is fully charged. |
All status LEDs blink in sequence. | No battery is inserted into any port. |
Charging Logic
Power of charger | Charging sequence |
10 W≤ Charger Power <30 W | Charges in sequence from a high to low battery level. |
30 W ≤ Charger Power < 45 W | Charges two batteries simultaneously: First charge the battery with a lower battery level to the same level as the highest one and then charge the two batteries simultaneously. |
Charger Power ≥ 45 W | Charges three batteries simultaneously: First charge the two batteries with a lower battery level to the same level as the highest one and then charge the batteries simultaneously. |
DJI Mini Series
DJI Mini 5 Pro Two-Way Charging Hub
Compatible products: DJI Mini 5 Pro, DJI Mini 4 Pro, DJI Mini 3 Pro, DJI Mini 3
DJI Mini 4 Pro/Mini 3 Series Two-Way Charging Hub
Compatible products: DJI Mini 4 Pro, DJI Mini 3 Pro, DJI Mini 3
DJI Mini 2 Two-Way Charging Hub
Compatible products: DJI Mini 4K, DJI Mini 2 SE, DJI Mini 2, DJI Mini SE
Status LEDs in an array blink successively and slowly for approx. 30 seconds and then blink very slowly with 2-second intervals. | The battery in the corresponding battery port is charging very slowly (we suggest using a different USB-C cable). |
Mavic Mini Two-Way Charging Hub
Compatible product: Mavic Mini
DJI Avata Series
DJI Avata 360 Battery Charging Hub
Compatible product: DJI Avata 360
DJI Avata 2 Two-Way Charging Hub
Compatible product: DJI Avata 2
DJI Avata Battery Charging Hub
Solid yellow | No battery is attached. |
