Functional Description
In extremely low-light conditions, Osmo Action 6/Osmo Action 5 Pro shines with its AI noise reduction algorithms. Activate SuperNight Scene mode to tackle low-light challenges and achieve purer visuals.
Where to Set
Osmo Action 6/Osmo Action 5 Pro:
Swipe left or right in the center of the screen > SuperNight.
Osmo 360 Series
1. 360° Mode: Tap the mode switch icon in the lower left corner → 360° → swipe left or right → SuperNight.
2. Single Lens Mode: Tap the mode switch icon in the bottom left corner → Single Lens → Swipe left or right → SuperNight.
Notices
1. The Super Night mode supports 10-bit( Osmo Action 6)/8-bit( Osmo Action 5 Pro) color depth and a frame rate of ≤ 60fps.
2. It does not support HorizonBalancing, HorizonSteady, 155° ultra-wide angle, and 4:3 aspect ratio.
3. Osmo Action 6 does not support 9:16 vertical shooting in SuperNight mode.
Osmo 360 Series
1. The endurance mode in parameter adjustment only supports frame rates of 30fps and below.
2. SuperNight in Single-Lens Mode only supports standard 10-bit color.
