ActiveTrack
Applicable Products
Osmo Mobile Series, Osmo Pocket Series, Ronin Series
How to Use
Osmo Pocket Series
Check out Using ActiveTrack with Handheld Products to learn how to make the most of this feature for Osmo Pocket Series.
Osmo Mobile Series
Check out Using ActiveTrack with Handheld Products to learn how to make the most of this feature for Osmo Mobile Series.
Ronin Series
Check out How do I use ActiveTrack on DJI Ronin Series products? to learn how to make the most of this feature for Ronin Series.
Glamour Effects
Applicable Products
Osmo Nano, Osmo Mobile Series, Osmo Pocket Series
How to Use
Osmo Nano
Glamour effects are supported, which can be enabled by accessing camera parameter settings on the multifunctional vision dock and the Pro mode settings.
Osmo Pocket Series
Refer to this video for using the Glamour Effects function of Osmo Pocket Series.
Osmo Mobile Series
1. Power on the gimbal and connect it to the mobile device. Make sure the device is balanced properly.
2. Enter the DJI Mimo app, tap the “Glamour Effects” icon in the lower left corner to enable the feature.
[Tips] The Glamour Effects feature is supported only for photos, videos (except those shot in 4K resolution or at 60 fps), and dynamic zoom.
Panorama Mode
Applicable Products
Osmo 360 Series, Osmo Mobile Series, Osmo Pocket Series, Ronin Series
How to Use
Osmo Pocket Series
180° and 3×3 panorama modes are supported.
When 180° is selected, the camera will capture four shots from left to right and stitch them into a panoramic photo.
When 3×3 is selected, the camera will take nine shots in different directions and stitch them into a panoramic photo.
[Tips] View Panorama photos in the DJI Mimo app only.
Click here to learn how to use the panorama shooting function of the Osmo Pocket series products. (Using Osmo Pocket as an example)
Osmo Mobile Series
There are three different panorama modes, all of which support landscape and portrait shooting:
1. 3×3 Panorama automatically takes and stitches together nine photos.
2. 240° Panorama automatically takes and merges seven photos.
3. CloneMe Panorama automatically takes and merges three photos.
Uses the CloneMe Panorama feature on DJI OM 4 to demonstrate how to use the Panorama shooting function of the Osmo Mobile series products.
Ronin Series
Make sure the camera is attached to the gimbal, connected via the camera control cable, and balanced before using the Panorama mode on Ronin series products.
The video below shows how to use the Panorama shooting feature on Ronin series products by accessing it through the app:
Operations:
DJI RS 4 Mini, DJI RS 4 Pro, DJI RS 4, DJI RS 3 Pro, and DJI RS 3
• Via Built-in Screen: Slide left from the right edge of the screen > Panorama
• Via DJI Ronin App: DJI Ronin > Create > Panorama
DJI RS 3 Mini
DJI RS 2
• Via Built-in Screen: Slide right from the left edge of the screen > Panorama
DJI RSC 2, Ronin-SC, & Ronin-S
Timelapse
Applicable Products
Osmo Nano, Osmo 360 Series, Osmo Action Series, Osmo Mobile Series, Osmo Pocket Series, Ronin Series
How to Use
Osmo Nano
Osmo Nano supports recording Timelapse and Hyperlapse videos.
Osmo Action Series
Check out Using Timelapse with Handheld Products to learn how to make the most of this feature for Osmo Action Series.
Osmo Pocket Series
Check out Using Timelapse with Handheld Products to learn how to make the most of this feature for Osmo Pocket Series.
Osmo Mobile Series
Check out Using Timelapse with Handheld Products to learn how to make the most of this feature for Osmo Mobile Series.
Ronin Series
Refer to this video for using the Timelapse function of Ronin series products:
Operations:
• Via Built-in Screen: Slide left from the right edge of the screen > Timelapse.
• Via DJI Ronin App: DJI Ronin > Create > Timelapse.
DJI RS 3 Mini
DJI RS 2
• Via Built-in Screen: Slide right from the left edge of the screen > Timelapse.
