Issue Description:
The display of the DJI Power indicates "ERR67", and the DJI Home app prompts "Communication error between main board and battery management system (BMS)".
Solution
1.Check if the firmware version of the power station is the latest. If not, connect it to DJI Assistant 2 (Power Series) or to the Home app (excluding DJI Power 500) to update to the latest firmware.
2. Power off the power station by pressing and holding the power button. Then press and hold the button again to power it on after 30 seconds.
If the above solution does not resolve your issue, please contact DJI Support.
