1. In the Box
Unbox your package to discover the product and accessories. Ensure everything matches the checklist and is in perfect condition. Check out the image below for more details.
• DJI Mavic 4 Pro (DJI RC 2)
• DJI Mavic 4 Pro Fly More Combo (DJI RC 2)
• DJI Mavic 4 Pro 512GB Creator Combo (DJI RC Pro 2)
2. Pre-Flight Preparations
2.1 Preparing the Aircraft
• Download App
Some features require the DJI Fly app. Click here to download the app.
• Remove the Storage Cover
Release the strap, and then remove the storage cover.
• Activate the Battery
Activating the Battery: Press the power button once to activate the aircraft battery and check the battery level.
Charging Method: Ensure the intelligent flight battery is fully charged before each use.
① Connect the aircraft to a DJI power adapter via the USB-C port for charging the battery.
② Use the charging hub to charge the batteries.
[Tips] Charging is not supported when the aircraft is powered on.
• Power On/Off
Automatic Power-On: Unfolding the right rear arm will power on the aircraft by default.
Automatic Power-Off: Folding the right rear arm will initiate an automatic countdown for power-off. During the countdown, press the power button once to cancel it (the automatic power-off feature is disabled by default and needs to be enabled in the DJI Fly app).
Manual Power-On/Power-Off: Press once, then press and hold the power button for 2 s to manually power on or off the aircraft.
• Install the Propeller
Propellers are pre-installed upon shipment. If the propeller is damaged or misshapen, please refer to the tutorial video for replacement.
2.2 Preparing the Remote Controller
• DJI RC Pro 2
Automatic Power-On: Unfold the antennas downward and the screen to quickly power on the remote controller.
Manual Power-On/Power-Off: Press once, then press and hold the power button for 2s to manually power on or off the remote controller.
Charging Method: Connect the remote controller to a charger via USB-C port.
Refer to the tutorial video in the following to learn how to set the language, activate the remote controller, and more.
• DJI RC 2
Manual Power-On/Power-Off: Press once, then press and hold the power button for 2 s to manually power on or off the remote controller.
Refer to the tutorial video in the following to learn how to install the control stick, set the language, activate the remote controller, and more.
2.3 Connection and Linking
If you purchase an aircraft and remote controller combo, the remote controller is already linked to the aircraft upon shipment. You can use them directly after activation upon powering on. In other cases, please refer to the tutorial video for linking.
• DJI RC Pro 2
• DJI RC 2 (Taking DJI Air 3 as an example)
2.4 Activating the Aircraft
The aircraft needs to be activated via DJI Fly when it is used for the first time. Open the DJI Fly app and follow the on-screen instructions. Please ensure that your device remains connected to the internet during the activation process.
After activation, the aircraft will be bound to the remote controller used during activation process by default.
You can go to the Device Info Inquiry page to check the activation information, warranty period, and DJI Care service plan benefits.
2.5 Firmware Update
A prompt will appear in DJI Fly when a firmware update is available. Update the firmware following the corresponding instructions to ensure an optimal flight experience.
[Tips]
① During an update, please do not power off the device or exit the DJI Fly app.
② After the update is completed, the aircraft will be automatically powered off. Restart it manually.
2.6 Setting Obstacle Avoidance
Make sure the remote controller is in N mode (Normal). Open the DJI Fly app, go to safety settings, set Obstacle Avoidance Action as Bypass or Brake, and adjust the RTH altitude to be higher than the tallest building or object around.
[Tips] In S mode (Sport), obstacle avoidance will be disabled automatically.
2.7 Checking Your Device
1. Please remove the gimbal protector before powering on your aircraft.
2. Make sure the battery, the propellers, and the control sticks are installed properly and securely, and the front and rear arms are fully unfolded.
3. Check if the aircraft and remote controller have sufficient battery levels.
4. Ensure the satellite positioning signal icon remains white before takeoff.
2.8 Flight Simulator
Before your first flight, we recommend using DJI Fly’s flight simulator to practice and learn flying skills, ensuring a safe and smooth real flight experience.
[Tips] DJI RC Pro 2 features a flight simulator function, while DJI RC 2 does not support this function yet.
3. For Beginners
3.1 Flight Policies
Stay informed about the latest information on flight zones, flight restrictions, and requirements before flight. Strictly adhere to them while operating your aircraft.
▸ For GEO Zone information near you, please tap “Before You Fly” in DJI Fly.
▸ For flight safety regulations in different countries and regions, please explore our Compilation of Global Flight Safety Regulations.
3.2 Flight Environment Requirements
Although the aircraft supports obstacle avoidance, it is recommended to fly in open areas that have good lighting without obstacles.
▸ Do not direct the aircraft towards people, animals, small objects (such as branches or wires), or transparent objects (such as glass or water surfaces).
▸ Do not fly on rainy or foggy days, or in any other conditions with low visibility (less than 100 m).
For more flight safety information, please refer to Flight Safety Essentials, which covers key points for responding to flight environments, prevention and management of flight incidents, as well as global flight safety regulations.
3.3 Protecting Your Device
To maintain your aircraft in the best condition over time, please take care of important parts during use.
Camera: Avoid exposing the camera lens to environments with laser beams (such as laser shows) or capturing objects which have intense light sources (such as the sun) for a long time to prevent damage to the sensor.
Gimbal: Avoid collisions or damage, as the gimbal contains delicate modules that could be impaired if harmed.
Intelligent Flight Battery and Remote Controller: Long-term storage may affect battery performance. To maintain battery health, it is recommended to charge it every three months.
4. Getting Ready for the First Flight
4.1 Takeoff and Landing
• Auto Takeoff and Landing
Takeoff: Tap the takeoff icon on the left, and press and hold the prompt icon to enable Auto Takeoff. The aircraft will take off automatically and hover at a certain height.
Landing: After takeoff, tap the landing icon on the left, and press and hold the prompt icon to land automatically. The aircraft will land automatically and stop the motor.
• Manual Takeoff and Landing
The control sticks can be operated in Mode 1, Mode 2, Mode 3, or Custom. The tutorial video demonstrates the operations using Mode 2.
Takeoff: Start the motor with the left and right control sticks by pushing them toward or away from each other. After the motors are spinning, release your hand and gently push the left stick upward to take off the aircraft.
Landing: Pull the left stick down to land the aircraft. After landing, keep pulling the left stick down until the motor stops.
• Controlling the Aircraft
Left Stick: Moving the left stick up or down changes the altitude of the aircraft and moving it to the left or right changes the orientation of the aircraft.
Right Stick: Moving the right stick up, down, to the left or to the right controls the forward, backward, left, or right movements of the aircraft.
4.2 Photo and Video
Focus/Shutter Button is on the upper right side of the remote controller. Press halfway down on the button to auto focus and press all the way down to take a photo. Record Button is on the left side. Press once to start or stop recording. For more detailed usage instructions, please refer to the tutorial video in the following.
• DJI RC Pro 2
• DJI RC 2
4.3 Intelligent Flight Features
• Infinity Gimbal
The infinity gimbal of DJI Mavic 4 Pro supports roll axis rotation, allowing angle adjustments in the shooting for more flexible camera movements.
• Cruise Control
The cruise control function enables the aircraft to lock the current control stick input of the remote controller when conditions permit and fly at the speed corresponding to the current control stick input, which frees your hands and making long-distance flights more effortless.
• FocusTrack
FocusTrack includes three types of camera movements: Spotlight, Point of Interest (POI), and ActiveTrack. For more usage instructions, please refer to the video in the following (taking DJI Air 3S as an example).
• Panorama
Panorama modes include Free Panorama, Sphere, 180°, Wide Angle, and Vertical. For more usage instructions, please refer to the video in the following (taking DJI Air 3S as an example).
• More Flight Features
DJI Mavic 4 Pro also supports MasterShots, QuickShots, Hyperlapse, and other intelligent flight modes. For more usage instructions, please check the tutorial video here.
4.4 Return to Home (RTH)
The aircraft supports RTH, which can be triggered in three ways: the user proactively triggers, the aircraft battery level is low, or the remote controller signal is lost.
5. Accessory Usage
DJI Mavic 4 Pro Propeller Guard
The propeller guard can fully wrap the propellers to avoid injury or damage by obstacles.
6. After Flight
6.1 Exporting Photos and Videos
The aircraft comes with an internal storage of 64GB*/512GB* and also supports storage expansion via microSD card.
*DJI Mavic 4 Pro comes with a 64GB internal storage.
*DJI Mavic 4 Pro 512GB comes with a 512GB internal storage.
• Export via QuickTransfer
The QuickTransfer feature allows photos and videos stored in the aircraft or microSD card to be quickly and conveniently transferred to a mobile device.
Refer to the following tutorial to learn about the QuickTransfer in Sleep mode:
• Export via USB-C cable or card reader
Connect the aircraft to a computer using a DJI USB-C cable to export photos or videos from the aircraft’s internal storage or the microSD card installed in the aircraft. The aircraft does not need to be powered on during export. You can also remove the microSD card from the aircraft, insert it into a card reader, and export the footage using the card reader. Check Drone Photo or Video Files Export Guide here.
6.2 Storing Your Devices
Incorrect placement of the aircraft will compress the propellers, resulting in their deformation and a decline in propulsion performance. Watch the video to learn how to store your aircraft.
• DJI RC Pro 2
• DJI RC 2
7. After-Sales Service Policies
7.1 Warranty
If the product malfunctions due to non-user error during the warranty period, click here to apply for free repair service. Please refer to Warranty Period of Main Parts.
7.2 DJI Care Service Plan
DJI Care Refresh is a comprehensive and reliable protection plan that provides DJI products with coverage for a range of accidental damages such as collision, water damage, flyaway, and natural wear.
>> Purchase DJI Care Refresh Now
>> View DJI Care Refresh Terms of Service
8. FAQs
• What is the difference between DJI Mavic 4 Pro and DJI Mavic 4 Pro 512GB?
A: The main differences are in hardware, features, and appearance. The details are as follows:
Hardware: DJI Mavic 4 Pro 512GB comes with 512GB of internal storage, while DJI Mavic 4 Pro comes with 64GB of internal storage.
Features: DJI Mavic 4 Pro 512GB supports ALL-I encoding and can take 10-bit 4:2:2 videos, allowing for richer color information and a smoother post-editing experience. It also supports timelapse recording with intervals as short as 1 s.
Appearance: There are different stickers inside the battery compartment: the 512GB version has a "512GB" sticker, while the standard version has a "64GB" sticker.
• Does DJI RC Pro 2 support installing third-party apps?
A: Yes. You can download third-party apps through the built-in browser or install APK files from a microSD card.
(DJI will not be liable for any permission or safety issues resulting from use of third-party apps. If an installed third-party app prevents optimal use of your controller, it is suggested to remove the app or restore the controller to original factory settings.)
For more information about the product, please refer to the user manual.
9. Service and Support
▸ Device Info Inquiry: Get easy access to your device info at any time, including activation date, warranty status, and service history.
▸ Replacement Service: If your device encounters any issues within 30 days of receiving it and meets the replacement criteria, we provide a convenient replacement service.
▸ Service Progress Inquiry: Keep track of your device's repair progress in real-time, including service details like quotation, delivery information, and inspection report, allowing you to stay informed about the service progress.
