Purpose
· The purpose of this document is to show users how to repair the DJI product, and list common issues and their solutions, but for complex exceptions or error messages, it is recommended to contact DJI Support for assistance.
· To find the related product features and usage information, please visit the DJI’s official website at http://www.dji.com/.
Notices
· Keep the product and other modules away from children.
· Do not let the product come into contact with liquid or water.
· Do not power on the product immediately after it has fallen into water.
· Do not store the product in a humid area.
Battery Safety Notices
· Do not allow a battery to come into contact with any kind of liquid, or leave it out in the water.
· Do not use swollen, leaking, or damaged batteries.
· Do not install or remove a battery when it is turned on.
· Use a battery at temperatures from -10℃ to 40℃.
· Do not use batteries in strong electrostatic or electromagnetic environments.
· Do not disassemble or pierce batteries in any way.
· Do not place wires or metal objects on a battery. Otherwise, the battery may short-circuit.
· Do not drop or strike a battery, or place heavy objects on the battery.
· Electrolytes in batteries are highly corrosive. In the event of a leakage, please stay away from the battery.
· Keep batteries out of the reach of children.
· Do not leave batteries near heat sources.
· Keep batteries dry.
· Keep batteries away from the metal objects, such as glasses, watches, or necklace during transportation or storage.
· Do not transport a damaged battery.
· Do not store batteries in environments with a temperature higher than 45℃ or lower than 0℃.
· Do not place batteries in regular trash containers.
Applicable Models
No. | Model | No. | Model |
1 | Phantom 4 Pro V2.0 | 21 | DJI Air 3 |
2 | Mavic 3 | 22 | Mavic Mini |
3 | Mavic 3 Cine | 23 | Mavic 2 Pro |
4 | Mavic 3 Classic | 24 | Mavic 2 Zoom |
5 | Mavic 3 Pro | 25 | Mavic Air |
6 | Mavic 3 Pro Cine | 26 | Mavic Pro Alpine White |
7 | DJI Air 2S | 27 | Mavic Pro Platinum |
8 | Mavic Air 2 | 28 | Mavic Pro |
9 | DJI Mini 3 Pro | 29 | DJI RC Pro 2 |
10 | DJI Mini 3 | 30 | DJI RC-N1C |
11 | DJI Mini 2 | 31 | DJI RC-N2 |
12 | DJI Mini 2 SE | 32 | DJI RC 2 |
13 | DJI Mini SE | 33 | Phantom 4 Pro+ |
14 | DJI RC | 34 | Phantom 4 Advanced+ |
15 | DJI RC Pro | 35 | Phantom 4 Pro V2.0 |
16 | DJI Mini 5 Pro | 36 | Phantom 4 Pro |
17 | DJI Mavic 4 Pro | 37 | Phantom 3 Standard |
18 | DJI Air 3S | 38 | Phantom 3 4K |
19 | DJI Mini 4K | 39 | Phantom 3 SE |
20 | DJI Mini 4 Pro | 40 | Phantom 3 Advanced |
41 | Phantom 3 Professional |
Aircraft
Common Issue | Inspection Method | Repair Method |
Aircraft arm broken or skewed | Perform visual inspection and check if the aircraft arm is cracked and cannot be used normally. | Replace the aircraft. |
Upper cover cracked or misshapen | Perform visual inspection and check if the upper cover is obviously cracked or misshapen, or if there are any other cosmetic damages. | Replace the aircraft. |
Gimbal axis arm broken | Perform visual inspection and check if the gimbal axis arm is obviously cracked or misshapen, or if there are any other cosmetic damages. | Replace the aircraft. |
Abnormal camera image | Enter the camera view in the app and check if the image is displayed abnormally, such as blurry image, stripes, and noises. | Replace the aircraft. |
Gimbal stabilization error | Enter the camera view in the app and check if the image is skewed or shaking. | Replace the aircraft. |
Propulsion system error | Turn on the motors and check if the motors are spinning correctly. | Replace the aircraft. |
Camera sensor error | Check if the app prompts a “Camera Sensor Error” warning. | Replace the aircraft. |
App prompts GPS disconnected warning | Check if the app prompts a “GPS disconnected” warning. | Replace the aircraft. |
Remote Controller
Upper shell cracked or misshapen | Perform visual inspection and check if the upper shell is obviously cracked or misshapen, or if there are any other cosmetic damages. | Replace the remote controller. |
Lower shell cracked or misshapen | Perform visual inspection and check if the lower shell is obviously cracked or misshapen, or if there are any other cosmetic damages. | Replace the remote controller. |
Control sticks not re-center | Check if the drone response corresponds to the control stick input. | Use the app to calibrate the remote controller. If the issue persists, replace the remote controller. |
Power-on failure | Check if the remote controller can be powered on after charging. | Replace the remote controller. |
Remote controller GPS error | Check if the app prompts a “Remote Controller GPS Error” warning. | Replace the remote controller. |
Abnormal screen display | Perform visual inspection and check if the screen is black out or freezes, and if the screen is not displayed completely. | Replace the remote controller (with a built-in screen). |
Battery and Charger
Battery/charger outer shell cracked or misshapen | Perform visual inspection and check if there are any other cosmetic damages such as cracked and misshapen that may affect the normal use. | Replace the corresponding defective module. |
Battery charging error | Use a functioning normally battery charging hub to charge the battery and see if it can be charged. | Replace the corresponding defective module. |
Discharging error | Install the battery to the drone and check if the drone can be powered on. | Replace the corresponding defective module. |
Cable
Cable damaged | Perform visual inspection and check if the cable is damaged. | Replace the cable. |
Unable to connect the mobile phone | Replace the cable and check if the connection is normal. | Replace the cable. |
Other Accessories
Perform visual inspection and check if accessories are cracked or there is structural damage. Then replace the corresponding accessory.
