1. Unboxing
Unbox your package to discover the product and accessories. Ensure everything matches the checklist and is in perfect condition. Check out the image below for more details.
DJI Avata 360 (Drone Only)
Tips: The aircraft must be activated using a remote controller.
DJI Avata 360 (DJI RC 2)
DJI Avata 360 Fly More Combo (DJI RC 2)
DJI Avata 360 Motion Fly More Combo
2. Pre-Flight Preparations
2.1 Preparing the Aircraft
• Download App
Activation requires the DJI Fly app. Click here to download the app.
• Remove the Gimbal Protector
Remove the gimbal protector as shown in the illustration.
• Activate the Battery
Press the power button once to activate the aircraft battery and check the battery level.
• Charging Method
It is recommended to fully charge the Intelligent Flight Battery before each use.
① It is recommended to connect the aircraft to the official DJI charger via the USB-C port for charging.
Tips: Charging is not supported when the aircraft is powered on.
② Use the battery charging hub to charge the flight battery.
• Power On/Off
Press, then press and hold the power button for two seconds to power on or off the aircraft.
2.2 Preparing the Remote Controller and Goggles
• DJI RC 2
Charging Method: Fully charge the remote controller before each flight.
Mount the Control Sticks: Remove the control sticks from the storage slots and mount them on the remote controller.
Power On/Off: Press, then press and hold the power button for two seconds to power on or off the remote controller.
• DJI RC Motion 3
Charging Method
Power On/Off: Press, then press and hold the power button for two seconds to power on or off the motion controller.
• DJI Goggles N3
Charging Method: If the battery level is low, use a USB charger to charge the device.
Power On/Off: Press, then press and hold the power button for two seconds to power on or off the goggles.
2.3 Connection & Activation
Activation works differently depending on which combo you have, so follow the activation steps for the specific product combo you bought.
• DJI Avata 360 (DJI RC 2)
• DJI Avata 360 Motion Fly More Combo
2.4 Firmware Update
A prompt will appear in DJI Fly when a firmware update is available. Update the firmware following the corresponding instructions to ensure an optimal flight experience.
2.5 Flight Safety
2.5.1 Flight Policy
Stay informed about the latest information on flight zones, flight restrictions, and requirements before flight. Strictly adhere to them while operating your aircraft.
▸ For GEO Zone information near you, please tap "Before You Fly" in DJI Fly.
▸ For flight safety regulations in different countries and regions, please explore our Compilation of Global Flight Safety Regulations.
2.5.2 Flight Environment
▸ Do not fly in severe weather conditions such as strong winds, snow, rain, and fog.
▸ Avoid obstacles, crowds, and bodies of water. Do not fly the aircraft near airports, highways, railway stations, railway lines, city centers, or other sensitive areas, unless a permit or approval is obtained under local regulations.
▸ Minimize interference by avoiding areas such as power lines, base stations, and broadcasting towers.
▸ For more information on flight environment requirements, refer to the "Flight Safety" section in the User Manual.
For more flight safety information, please refer to Flight Safety Essentials, which covers key points for responding to flight environments, prevention and management of flight incidents, as well as global flight safety regulations.
2.5.3 Device Inspection
1. Make sure all protective parts are removed from the aircraft.
2. Make sure the battery, propellers, and control sticks are mounted properly and securely.
3. Make sure the aircraft and the remote controller are fully charged.
4. Make sure the RTH altitude is set higher than the tallest building or object in the area in DJI Fly or the goggles.
2.6 Usage Precautions
• To prevent accidental scratches on the lens, it is recommended to perform takeoff and landing on the included landing pad.
• Avoid exposing the camera lens to environments with laser beams (such as laser shows) or pointing the camera at intense light sources (such as the sun) for a long time to prevent damage to the sensor.
• Promptly attach the gimbal protector after use to protect the gimbal.
• If the battery is not used for an extended period, battery performance may be affected. It is recommended to fully charge the battery every 3 months to maintain battery health.
3. Getting Ready for the First Flight
DJI Avata 360 supports multiple control methods to meet the needs of different scenarios. Make sure you are familiar with the notice and usage for each control method before flight.
3.1 RC Control
The control sticks can be operated in Mode 1, Mode 2, Mode 3, or Custom. The tutorial video demonstrates the operations using Mode 2.
· Auto Takeoff and Landing: Tap the button on the left side of the camera view in the app, then press and hold the pop-up to make the aircraft take off automatically or return to home.
· Manual Takeoff and Landing: Start the motors with the left and right sticks by pushing them to the inner or outer bottom corners., then gently push the left stick upward to take off the aircraft. Pull the left stick down to land the aircraft. After landing, keep pulling the left stick down until the motors stop.
· Flight Control: Move the left stick to adjust the aircraft's altitude and orientation, and use the right stick to fly it forward, backward, left, or right.
· Photo Taking and Video Recording: The Shutter button is on the upper right side of the remote controller, and the Record button is on the upper left side.
· RTH: Press and hold the RTH button on the remote controller, or tap the RTH icon in the app and then press and hold the pop-up. The aircraft will automatically start returning to home.
3.2 Motion Control
Before your first flight with DJI RC Motion 3, you can watch the tutorial guide in the Goggles: Settings > Control. It is recommended to follow the on-screen instructions to learn the basic flight controls.
· Manual Takeoff and Landing: Press the Lock button twice to start the aircraft motors, then press and hold the Lock button for auto takeoff and hover. Press and hold the Lock button again for the aircraft to land and stop the motors automatically.
· Flight Control: Watch the video to see how to use the motion controller to fly the aircraft.
· Photo Taking and Video Recording: Press the Shutter/Record button once to take a photo or to start or stop recording. Press and hold the Shutter/Record button to switch between photo and video recording mode.
· Head Tracking: After enabling head tracking, the camera view will move with your head, without affecting the flight direction.
Tips: In Single Lens mode, after enabling head tracking, the horizontal direction of the aircraft and the gimbal tilt can be controlled using head movements during flight.
· RTH: Press and hold the mode button on the motion controller to initiate Advanced RTH. The aircraft will return to the Home Point and land.
3.3 Intelligent Features
3.3.1 360° Mode
Use with a remote controller
Use with goggles and motion controller
3.3.2 Easy ACRO
Easy ACRO must be used with goggles and motion controller.
3.3.3 FocusTrack
3.3.4 Camera View Sharing
You can share the camera view of the goggles with your friends and enjoy the flight together.
Share to a mobile device
Share to goggles
3.3.5 AR Cursor
The AR Cursor function of the motion controller can be used to control the goggles interface.
4. Charging Hub
The DJI Avata 360 charging hub supports charging and power accumulation.
5. After Flight
5.1 File Storage
The aircraft comes with built-in storage and also supports storage expansion via a microSD card. For details, refer to the recommended microSD card list.
5.2 Panoramic Editing
The captured panoramic videos must be edited before they can be exported and shared as flat videos. Use DJI Fly on your phone for quick editing or professional software on your computer for advanced editing.
· Edit on your phone
· Edit on your computer
5.3 File Exporting
DJI Avata 360 allows you to quickly export photos and videos using QuickTransfer or a data cable.
· QuickTransfer
· Data cable
5.4 Device Storage
· DJI Avata 360 (DJI RC 2)
· DJI Avata 360 Motion Fly More Combo
6. After-Sales Policies
6.1 Warranty Repair Service
If the product malfunctions due to non-user error during the warranty period, click here to apply for free repair service. Please refer to Warranty Period of Main Parts.
6.2 DJI Care Service Plan
DJI Care Refresh is a comprehensive and reliable protection plan that provides DJI products with coverage for a range of accidental damages such as collision, water damage, flyaway, and natural wear.
>> Purchase DJI Care Refresh (1-Year Plan)
>> Purchase DJI Care Refresh (2-Year Plan)
7. FAQs
• Which goggles and remote controllers are compatible with DJI Avata 360?
① Standard remote controllers: DJI RC 2, DJI RC-N2, and DJI RC-N3
② Motion controller (must be used with DJI Goggles 3 or DJI Goggles N3): DJI RC Motion 3
③ FPV remote controller (must be used with DJI Goggles 3 or DJI Goggles N3): DJI FPV Remote Controller 3
④ Goggles (must be used with DJI RC Motion 3 or DJI FPV Remote Controller 3): DJI Goggles 3 and DJI Goggles N3
• Does DJI Avata 360 support the Manual mode?
No.
For more information about the product, please refer to the User Manual.
8. Service and Support
▸ Device Info Inquiry: Get easy access to your device info at any time, including activation date, warranty status, and service history.
▸ Replacement Service: If your device encounters any issues within 30 days from the day after receiving it and meets the replacement criteria, we provide a convenient replacement service.
▸ Service Progress Inquiry: Keep track of your device's repair progress in real time, including service details like quotation, delivery information, and inspection report, allowing you to stay informed about the service progress.
