What is QuickShots?
QuickShots is an intelligent flight function of the DJI Lito Series, DJI Flip, DJI Avata 360, DJI Neo, DJI Air Series, DJI Mavic Series, DJI Mini Series, and Spark Series drones. QuickShots shooting modes include Dronie, Rocket, Circle, Helix, Boomerang, and Asteroid. The aircraft records according to the selected shooting mode and automatically generates a short video. The video can be viewed, edited, or shared on social media from playback.
Note: DJI Avata 360:DJI RC Motion 3, DJI FPV Controle Remoto 3 control does not support quickshots.
Introduction to QuickShots Modes
Dronie
The aircraft flies backward and ascends, with the camera locked on the subject, and records a video.
(The flight distance varies based on different models.
Product model | Flight Distance |
DJI Mini SE Mavic Mini | The default value is 25m and the setting range is 25m-40m. |
DJI Mini 2 Mavic Air 2 DJI Air 2S DJI Mavic 3 Series | The default value is 25m and the setting range is 25m-120m. |
DJI Lito 1 DJI Lito X1 DJI Avata 360 DJI Mini 5 Pro DJI Mavic 4 Pro DJI Air 3S DJI Mini 4 Pro DJI Air 3 DJI Mini 3 Pro DJI Mini 3 | The default value is 30m and the setting range is 30m-120m. |
DJI Neo 2 | The default value is 4m and the setting range is 2m-20m. |
DJI Flip DJI Neo | The default value is 4m and the setting range is 2m-10m. |
Helix
The aircraft ascends and spirals around the subject.
(The flight distance varies based on different models, and the flight direction can be set.
Product model | Inspection distance |
DJI Mini SE Mavic Mini | The default value is 25m and the setting range is 10m-40m. |
DJI Avata 360 DJI Mavic 4 Pro DJI Mini 2 Mavic Air 2 DJI Air 2S DJI Mavic 3 Series | The default value is 10m and the setting range is 10m-120m. |
DJI Lito 1 DJI Lito X1 DJI Mini 5 Pro DJI Air 3S DJI Mini 4 Pro DJI Air 3 DJI Mini 3 Pro DJI Mini 3 | The default value is 30m and the setting range is 10m-120m. |
DJI Neo 2 DJI Flip DJI Neo | The default value is 4m and the setting range is 4m-20m. |
Rocket
The aircraft ascends with the camera pointing downward.
(The flight distance varies based on different models.)
DJI Mini 2 Mavic Air 2 DJI Air 2S DJI Mavic 3 Series | The default value is 25 m and the setting range is 25m-80m. |
DJI Lito 1 DJI Lito X1 DJI Avata 360 DJI Mini 5 Pro DJI Mavic 4 Pro DJI Air 3S DJI Mini 4 Pro DJI Air 3 DJI Mini 3 Pro DJI Mini 3 | The default value is 30 m and the setting range is 30m-80m. |
DJI Neo 2 | The default value is 4m and the setting range is 4m-20m. |
DJI Flip DJI Neo | The default value is 4m and the setting range is 4m-10m. |
Circle
The aircraft circles around the subject.
Only the DJI Flip and DJI Avata 360, DJI Neo 2, DJI Neo can set the distance; the flight direction can be set for the following applicable products.
Applicable products: DJI Lito 1, DJI Lito X1, DJI Mini 5 Po, DJI Mavic 4 Pro, DJI Flip, DJI Air 3S, DJI Neo, DJI Mini 4 Pro, DJI Air 3, DJI Mavic 3 Series, DJI Mini Series, Mavic Air 2, DJI Air 2S, and DJI Mini 3 Pro, DJI Mini 3.
Boomerang
The aircraft flies around the subject in an oval path, ascending as it flies away from its starting point and descending as it flies back. The aircraft’s starting point forms one end of the oval’s long axis, while the other end is at the subject's opposite side from the starting point. Make sure there is sufficient space when using Boomerang. Allow a radius of at least 99 ft (30 m) around the aircraft and at least 33 ft (10 m) above the aircraft. The flight direction can be set.
Applicable products: DJI Lito 1, DJI Lito X1, DJI Neo 2, DJI Mini 5 Pro, DJI Mavic 4 Pro, DJI Air 3S, DJI Mini 4 Pro, DJI Air 3, DJI Mini 2, Mavic Air 2, DJI Air 2S, DJI Mavic 3 Series, and DJI Mini 3 Pro, DJI Mini 3.
Asteroid
The aircraft flies backward and upward, takes several photos, and then returns to the starting point. The video starts with a panorama of the highest position and then shows the descent. Make sure there is sufficient space when using Asteroid. Allow at least 132 ft (40 m) behind and 164 ft (50 m) above the aircraft.The flight direction and distance cannot be set.
Applicable products: DJI Lito 1, DJI Lito X1, DJI Avata 360, DJI Mini 5 Pro, DJI Air 3S, DJI Mini 4 Pro, DJI Air 3, Mavic Air 2, DJI Air 2S, DJI Mavic 3 Series, and DJI Mini 3 Pro, DJI Mini 3.
Using QuickShots
Please use QuickShots at locations that are clear of the building and other obstacles. If you are unfamiliar with the flight path of “QuickShots,” please do a short flight on the first attempt.
1. Tap the shooting mode icon on the right side of the camera view.
2. Swipe down and select “QuickShots”. Then choose a “QuickShots” shooting mode.
3. Select your target subject in the camera view by tapping “+” or drag-select the target. Tap “Start” to begin recording.
Watch this video to learn about how to use QuickShots:
Existing QuickShots
Press the Flight Pause/RTH button of the remote controller once or tap “X” in DJI Fly to exit QuickShots. The aircraft will brake and hover in place.
Resolution of QuickShots
Product Model | QuickShots | Resolution | fps | Video Format |
DJI Lito 1 DJI Lito X1 | Dronie | 1080P/2.7K/4K | 30/60 | MP4 |
Helix | ||||
Circle | ||||
Boomerang | ||||
Rocket | ||||
Asteroid | ||||
DJI Avata 360 | Circle | 360° Mode Lens: 8K (2:1): 7680 × 3840@60/50/48/30/25/24fps 6K (2:1): 6000 × 3000@60/5 | 24/25/30/48/50/60 | MP4 |
Boomerang | ||||
Dronie | ||||
Rocket | ||||
Helix | ||||
Spin | ||||
DJI Neo 2 | Circle | 1080P 4K | 30/50/60 | MP4 |
Boomerang | ||||
Dronie | ||||
Rocket | ||||
Helix | ||||
DJI Mini 5 Pro | Circle | 1080P 4K | 30/60 | MP4 |
Boomerang | ||||
Dronie | ||||
Rocket | ||||
Helix | ||||
Asteroid | ||||
DJI Mavic 4 Pro | Rotation | 1080P 4K 6K | 30/60 | MP4 |
Circle | ||||
Boomerang | ||||
Dronie | ||||
Rocket | ||||
Helix | ||||
Asteroid(The Medium and Tele Camera is not effective) | 1080P | 30 | ||
DJI Mini 4 Pro | Circle | 1080P 4K | 30/60 | MP4 |
Boomerang | ||||
Dronie | ||||
Rocket | ||||
Helix | ||||
Asteroid | ||||
DJI Flip | Circle | 1080P 1080P(9:16) 2.7K 4K | 30/60 | MP4 |
Boomerang | ||||
Dronie | ||||
Rocket | ||||
Helix | ||||
Asteroid | 1080P | 30 | MP4 | |
DJI Neo | Circle | 1080P 4K | 30/60 | MP4 |
Boomerang | ||||
Dronie | ||||
Rocket | ||||
Helix | ||||
Asteroid | ||||
DJI Air 3S | Dronie | 1080P 2.7K(9:16) 4K | 30/60 | MP4 |
Helix | ||||
Circle | ||||
Boomerang | ||||
Rocket | ||||
Asteroid (The 3x scope is not working) | 1080P | 30 | ||
DJI Air 3 | Dronie | 1080P 1080P(9:16) 2.7K(9:16) 4K | 30/60 | MP4 |
Helix | ||||
Circle | ||||
Boomerang | ||||
Rocket | ||||
Asteroid(The 3x scope is not working) | 1080P | 30 | ||
DJI Mini 3 | Dronie | 1080P 2.7K 4K | 30 | MP4 |
Helix | ||||
Circle | ||||
Boomerang | ||||
Rocket | 1080P | |||
DJI Mini 3 Pro | Dronie | 1080P 2.7K 4K | 30 | MP4/MOV |
Helix | ||||
Circle | ||||
Boomerang | ||||
Rocket | ||||
Asteroid | 1080P | |||
DJI Mavic 3 Pro DJI Mavic 3 DJI Mavic 3 Classic | Dronie | 1080P 4K | 30 | MP4/MOV |
Helix | ||||
Circle | ||||
Boomerang | ||||
Rocket | ||||
DJI Mini SE DJI Mini 2 SE | Helix | 1080P 2.7K | 30 | MP4/MOV |
Dronie | ||||
Circle | ||||
Boomerang | ||||
Rocket | ||||
DJI Air 2S | Dronie | 1080P 2.7K 4K | 30 | MP4/MOV |
Helix | ||||
Circle | ||||
Boomerang | ||||
Rocket | ||||
DJI Mini 2 | Dronie | 1080P 2.7K 4K | 30 | MP4/MOV |
Helix | ||||
Circle | ||||
Boomerang | ||||
Rocket | ||||
Mavic Air 2 | Dronie | 1080P 2.7K 4K | 30 | MP4/MOV |
Helix | ||||
Circle | ||||
Boomerang | ||||
Rocket | ||||
Mavic Mini | Dronie | 1080P 2.7K | 2.7K: 24/25/30fps 1080P: 24/25/30/48/50/60fps | MP4 |
Circle | ||||
Boomerang | ||||
Rocket | ||||
Mavic 2 | Dronie | 1080P | 30 | MP4/MOV |
Helix | ||||
Circle | ||||
Boomerang | ||||
Rocket | ||||
Asteroid | ||||
Mavic Air | Dronie | 1080P | 30 | MP4/MOV |
Helix | ||||
Circle | ||||
Boomerang | ||||
Rocket | ||||
Asteroid |
To understand the DJI GO 4 Quick Shots, read: Introduction to QuickShots via DJI GO 4
