When using the battery charging hub, the batteries will be charged in sequence according to their power levels, from high to low.
[Tips] The aircraft does not support charging while powered on.
DJI Mavic Series
DJI Mavic 4 Pro
Connect the aircraft to a DJI power adapter via the USB-C port for charging the battery.
Use the charging hub to charge the batteries.
Charging time
Using the DJI Mavic 240W Power Adapter to charge 1 battery: Approx. 51 minutes.
Using the DJI Mavic 240W Power Adapter to charge 3 batteries: Approx. 90 minutes (200 V to 240 V input) or 110 minutes (100 V to 127 V input).
Using the DJI 100W USB-C Power Adapter to charge 1 battery: Approx. 80 minutes.
Charging via the aircraft (65W max charging power): Approx. 115 minutes.
DJI Mavic 3 Series
Charging the battery
Insert the battery to the aircraft, connect the provided DJI 65W Portable Charger to the USB-C port of the aircraft, and the Battery Level LEDs in an array blink successively. The charging time for one battery is approximately 1 hour and 36 minutes. After fully charged, the four Battery Level LEDs are off. Detach the charger after charging is complete.
Using the Battery Charging Hub
Insert the batteries into the charging hub, connect the charger to the USB-C port of the charging hub, and the Status LEDs in an array blink successively.
The battery can be fully charged in about 1 hours and 36 minutes by used with the DJI 65W Portable Charger. After the battery is fully charged, the corresponding LEDs will change to solid green. The battery can be disconnected from the charging hub when charging is complete.
Method 1: A Type-C to Type-C PD fast charging cable is included in the package. Additionally, a USB charger* is required for charging your drone. It takes approximately 70 minutes to fully charge one battery.
*The USB charger needs to be prepared separately. It is recommended to use the charging devices provided by DJI, or other USB-C chargers that support PD fast charging protocols.
Method 2: If you purchase the Fly More combo, you can insert all the batteries into the charging hub until they click into place. Then connect the charging hub to a charger via a USB-C port for charging batteries. If the charger’s power is 65W or above, the charging hub can charge two batteries simultaneously, taking approximately 70 minutes to fully charge both.
DJI Air Series
DJI Air 3S/DJI Air 3
• Connecting the aircraft with the battery mounted to a charger for charging
Attach the aircraft to the charger with the battery powered off.
• Using the Battery Charging Hub
The Intelligent Flight Battery with the highest power level will be charged first, and then the rest will be charged in sequence according to their power levels.
The charging hub can use the power accumulation function to transfer the remaining power of multiple low-power batteries into the battery with the highest remaining power.
After the batteries are installed, the charging hub can supply power to external devices via the USB-C port, such as remote controllers or mobile phones.
• Charging Duration
The battery level LEDs of the battery and remote controller blink in sequence to display the current battery level during charging. After fully charged, the four Battery Level LEDs emit a solid light.
USB Charger (9V,3A)
USB Charger (5V,2A)
DJI Air 3 Intelligent Flight Battery
Connecting the aircraft with the battery mounted: Approx. 80 min;
Using the Battery Charging Hub: Approx. 60 min;
Using the Battery Charging Hub: Approx. 80 min;
DJI RC-N2
150 min
DJI RC 2
90 min
* Devices will take longer to charge if both ports are used for charging simultaneously. Tested in a lab environment and should be taken as reference only.
DJI Air 2S
Connect the battery to the charger and the Battery Level LEDs in an array blink successively. The charging time for one battery is approximately 1 hour and 35 minutes. After fully charged, the four Battery Level LEDs are off. Detach the charger after charging is complete.
Insert the batteries into the charging hub, connect the charger to the charging hub, and the Status LEDs in an array blink successively. The battery can be fully charged in about 1 hours and 35 minutes. After the battery is fully charged, the corresponding LEDs will change to solid green. The battery can be disconnected from the charging hub when charging is complete.
Mavic Air 2
DJI Neo Series
• Intelligent Flight Battery
Connect the USB charger to the USB-C port on DJI Neo to charge and activate the battery for the first time. When the battery level LEDs are on, it means the battery is successfully activated. It takes approximately one hour to fully charge one battery.
It is recommended to use a charger provided by DJI, such as DJI 65W Portable Charger or other USB PD chargers whose power output is no lower than 30 W.
• DJI Neo Two-Way Charging Hub
Insert the batteries into the battery ports of the charging hub until they click into place. Then connect the charging hub to a charger via USB-C port for charging batteries.
When used with the DJI 65W Portable Charger, the charging hub can fully charge three Intelligent Flight Batteries in approximately 60 minutes (it takes also approximately 60 minutes to fully charge one battery).
• DJI RC-N3 Remote Controller
Connect a charger to the USB-C port on the remote controller. It is recommended to use a 5V/2A charger. It takes approximately two hours to fully charge the remote controller.
DJI Neo 2
It is recommended to fully charge the Intelligent Flight Battery before each use.
① It is recommended to connect the aircraft to the official DJI charger via the USB-C port for charging.
Note: Charging is not supported when the aircraft is powered on.
② Use the battery charging hub to charge the battery.
DJI Mini Series
DJI Mini 5 Pro
Activate the Battery
Press the power button once to activate the aircraft battery and check the battery level.
Charging Method:
① Ensure the intelligent flight battery is fully charged before each use. It is recommended to connect the aircraft to the official DJI charger via the USB-C port for charging.
② Use the charging hub to charge the batteries.
DJI Mini 2, DJI Mini 2 SE, DJI Mini 4K
Insert the battery to the aircraft, connect the USB-C charger or PD fast charger to the USB-C port of the aircraft, and the Battery Level LEDs in an array blink successively. The charging time for one battery is approximately 1 hour and 22 minutes by using the DJI 18W Charger. After fully charged, the four Battery Level LEDs are on. Detach the charger after charging is complete.
Insert the batteries into the charging hub, connect the USB-C charger or PD fast charger to the USB-C port of the charging hub, and the Status LEDs in an array blink successively. The battery can be fully charged in about 1 hours and 22 minutes when used with the DJI 18W Charger. After the battery is fully charged, the corresponding LEDs will change to solid green. The battery can be disconnected from the charging hub when charging is complete.
* DJI 18W Charger is an optional accessory. Please click the link to purchase it.
DJI Mini 4 Pro
Fully charge the Intelligent Flight Battery before each use. It is recommended to use the charging devices provided by DJI, such as DJI Mini 3 Series Two-Way Charging HubDJI 30W USB-C Charger, or other USB Power Delivery chargers. Please follow the instructions provided below to properly charge the Intelligent Flight Battery and remote controller:
The battery cannot be charged if the aircraft is powered on.
• Charging Duration
During the charging process, the battery level LEDs of both the Intelligent Flight Battery and the remote controller will blink sequentially, indicating the current battery level. After fully charged, the four Battery Level LEDs emit a solid light.  Please disconnect the aircraft and charger.
9V/3A USB Charger
5V/2A USB Charger
DJI Mini 4 Pro Intelligent Flight Battery
Connecting the aircraft with the battery mounted: Approx. 70 min;
Using the Battery Charging Hub: Approx. 58 min
DJI Mini 3 Series Intelligent Flight Battery Plus (Compatible)
Connecting the aircraft with the battery mounted: Approx. 101 min;
Using the Battery Charging Hub: Approx. 78 min
DJI RC-N2
150 min
DJI RC 2
90 min
DJI Mini 3
• Charging the drone’s battery
Charging one battery: It takes about 1 hour and 4 minutes to charge the battery by using the DJI 30W USB-C charger (1 hour and 41 minutes for Intelligent Flight Battery Plus).
Using a battery charging hub: When used with the DJI 30W USB-C charger, the battery charging hub can fully charge one battery in approximately 56 minutes and one Intelligent Flight Battery Plus in approximately 78 minutes.
• Charging the remote controller’s battery
DJI RC: The battery can be fully charged in about 1 hour and 30 minutes by a charger with a maximum charging power of 15 W.
DJI RC-N1: The battery can be fully charged in about 3 hours and 30 minutes by a charger with a maximum charging power of 10 W.
DJI Mini 3 Pro
When using the DJI 30W USB-C charger, it takes about 1 hour and 4 minutes to charge the battery (1 hour and 41 minutes for Intelligent Flight Battery Plus). After fully charged, the four Battery Level LEDs emit a solid light. Remove the charger after charging is complete.
Insert the batteries into the charging hub, connect the USB charger or PD fast charger to the USB-C port of the charging hub, and the Status LEDs in an array blink successively.
When used with the DJI 30W USB-C charger, the battery charging hub can fully charge one battery in approximately 56 minutes and one Intelligent Flight Battery Plus in approximately 78 minutes. After the battery is fully charged, the corresponding LEDs will change to solid green. The battery can be disconnected from the charging hub when charging is complete.
The DJI 30W USB-C Charger is an optional accessory, and you can click on the link to purchase.
As the aircraft will naturally generate heat when charging the battery mounted on the aircraft, the charging power will be limited, and the charging time will be slightly longer than when using the battery charging hub.
DJI Mini SE
DJI Avata Series
DJI Avata 360
Tips: Charging is not supported when the aircraft is powered on.
② Use the battery charging hub to charge the flight battery.
DJI Avata 2
Ensure a seamless flying experience by fully charging your Intelligent Flight Battery before each use. It is recommended that you use DJI's dedicated charging devices, including DJI Avata 2 Two-Way Charging Hub and DJI 65W Portable Charger. Alternatively, you can also rely on other chargers that support the USB PD fast charging protocol. Both DJI Avata 2 Two-Way Charging Hub and DJI 65W Portable Charger are optional accessories. For detailed instructions on how to charge your device, refer to the following content:
• Charge the drone
• Charge the goggles
• Charge the motion controller
Connect the battery to the charger, and the Battery Level LEDs in an array blink successively. The charging time for one battery is approximately 50 minutes. After the battery is fully charged, the four Battery Level LEDs are off. Detach the charger after charging is complete.
Insert the batteries into the charging hub, connect the charger to the charging hub, and the Status LEDs in an array blink successively. The battery can be fully charged in about 50 minutes. After the battery is fully charged, the corresponding LEDs will change to solid green. The battery can be disconnected from the charging hub when charging is complete.
Phantom 4 Pro/Pro V2.0
Connect the battery to the charger, and the Battery Level LEDs in an array blink successively. The charging time for one battery is approximately 1 hour and 30 minutes. After fully charged, the four Battery Level LEDs are off. Detach the charger after charging is complete.
Insert the batteries into the charging hub, connect the charger to the charging hub, and the Status LEDs in an array blink successively. The battery can be fully charged in about 1 hour and 30 minutes. After the battery is fully charged, the corresponding LEDs will change to solid green. The battery can be disconnected from the charging hub when charging is complete.
