Supported Camera Models
Please refer to DJI Ronin Image Transmitter Compatibility List to check the compatible camera model and corresponding camera control cable.
Installing the DJI Ronin Image Transmitter
Click Here to view tutorials for installation of DJI Ronin Image Transmitter.
You can also refer to the following methods to learn how to install DJI Ronin Image Transmitter:
Operation Steps
1. Mount your camera to the gimbal, and install the DJI Ronin Image Transmitter to the cold shoe port of the camera mounting plate.
DJI RS 4 Pro, DJI RS 4, DJI RS 3 Pro, DJI RS 3 and DJI RS 2:
DJI RSC 2:
2. Choose the HDMI cable according to the HMDI port of your camera to connect the DJI Ronin Image Transmitter with the camera. Then use a USB-C to USB-C (200 mm) cable to connect the charging port of the DJI Ronin Image Transmitter and the image transmission port on the gimbal tilt axis.
DJI RS 4 Pro, DJI RS 4, DJI RS 3 Pro, DJI RS 3, and DJI RS 2:
DJI RSC 2:
3. Use the camera control cable (please check the Ronin Camera Compatibility List for compatible camera control cable) to connect the gimbal with the camera, and balance the gimbal.
4.Power on the gimbal and DJI Ronin Image Transmitter, and run the DJI Ronin app to check the camera view remotely.
💡[Tips]
① DJI Ronin Image Transmitter can only connect to one app (mobile device) at a time.
② DJI Ronin Image Transmitter does not come with an HDMI output port, so it only supports connecting to an app of the mobile device and outputs images through Wi-Fi.
③ iOS devices do not support direct connection to DJI Ronin Image Transmitter Wi-Fi through the app. You need to connect through the Wi-Fi settings page for connection.
④ The brand new DJI Ronin Image Transmitter does not have a default password. If a password is required during the first connection, enter "12345678" or reset the DJI Ronin Image Transmitter's Wi-Fi by pressing the power button six times consecutively.
