What is the battery cycle count?
The battery cycle count is an important indicator of whether a battery needs to be replaced.
When the battery cycles exceed a certain number, the battery enters a state of strong depletion. Even if the battery can still be used, the battery life and performance will naturally decline.
How to calculate the battery cycle count?
The battery cycle will be counted once when 75% of the rated battery capacity mentioned in the official manual is consumed, including consumption by the battery’s self-discharge.
For example,
If the aircraft begins flying with a battery level of 100%, one cycle is recorded once the battery level depletes of 25%.
Each time the battery level is drained from 50% to 0% and then fully recharged, with subsequent depletion of 25%, a total of 75% of the battery capacity has been discharged, so one cycle is also counted.
How to check the battery cycle count?
DJI Fly: Tap the three-dot icon in the top right corner of the camera view to enter Settings, then tap “Safety” > “Battery Info”.
DJI GO 4: Tap the three-dot icon in the top right corner of the camera view to enter Settings, and tap the battery icon > “Details”.
FAQs
1. Is a battery cycle count recorded when the DJI Mini 2 Two-Way Charging Hub or DJI Mini 3 Series Two-Way Charging Hub is used as a mobile power supply?
If the DJI Mini 2 Two-Way Charging Hub or DJI Mini 3 Series Two-Way Charging Hub is used as a mobile power supply, the battery level will also be consumed, so the battery cycle count will also be recorded.
2. Does a battery become unusable when its cycle count reaches the number of cycles specified in the warranty?
No. As the cycle count increases, the battery's performance naturally declines, resulting in a shorter battery life compared to a new battery. However, with proper routine use and maintenance, the battery can still be used continuously. Click to learn more: Battery Routine Maintenance Guide.
