Installation Guide
Mounting the Accessory:
1. Please refer to DJI R Vertical Camera Mount Use Guidelines to replace the “camera mounting plate” of DJI RS 3 Pro/DJI RS 3/DJI RS 2 with the “DJI R Vertical Camera Mount”.
2. Mount DJI Ronin Image Transmitter onto the camera’s hot/cold shoe (if the camera does not have a hot/cold shoe, please fix the DJI R Vertical Camera Mount on the camera’s cage).
Using the DJI Ronin App
1. Connect to the Wi-Fi of the DJI Ronin Image Transmitter, and enter the camera view in the DJI Ronin app.
2. Tap “Remote Control”.
3. Tap “ActiveTrack”, and change “ActiveTrack Orientation” to “Portrait”.
Using the DJI RS 3 Pro or DJI RS 2 Touchscreen
1. DJI RS 2: Slide down on the touchscreen from the top to enter the camera view. DJI RS 3 Pro: Slide right from the left on the touchscreen to enter the camera view.
2. Tap the Settings button in the bottom-right corner to enter the Settings menu.
3. Enable “Portrait Follow”, and return to the camera view for performing ActiveTrack. At this time, the camera view will be displayed vertically.
💡[Tips]
1. When DJI RS 3 Pro, DJI RS 3, or DJI RS 2 is used with the DJI R Vertical Camera Mount, the camera view in the DJI Ronin app will turn left by 90°. so please turn the mobile device left by 90° for normal use.
2. If a third-party L-shaped mounting plate is being used, please ensure that the camera bottom is closed to the tilt motor before mounting.
1) When using ActiveTrack in Portrait mode with the DJI Ronin Image Transmitter, the camera view in the both DJI RS 3 or DJI RS 2 touchscreen and app will turn left by 90°.
2) If the camera’s hot/cold shoe is close to the tilt motor, the video will be in the reverse direction from the actual orientation after the video signal has been output to the DJI Ronin Image Transmitter, resulting in an ActiveTrack failure.
3. When DJI RS 3 Pro is used with DJI LiDAR Range Finder (RS), ActiveTrack in Portrait mode is not supported.
