Check Your System Version
Click here to go to the Download Center. You can check the supported macOS versions for DJI Assistant 2 under the version information section. For the specific location, please refer to the image below:
• If your device does not meet the requirements, please switch to a device that fulfills the system version criteria.
• If you are unable to switch devices, please contact DJI Support and provide a detailed description of your needs, such as firmware update, vision sensor calibration, log export, etc. We will provide you with a corresponding solution.
Installation Guide
When downloading DJI Assistant 2, directly clicking "OK" may lead to the following alert preventing the completion of the installation. At this time, you need to open the installation package from the "Security & Privacy" page to complete the installation. Here are detailed instructions:
1. Follow this path to find the "Security & Privacy" page: "System Preferences > Security & Privacy".
2. Under the "General" tab of "Security & Privacy," select "Open Anyway".
3. In the pop-up that appears, click "Open".
4. You should now be able to enter the software installation interface. After reviewing the "Introduction", click "Continue".
5. Read the "Software License Agreement", and if you agree with the information provided, click "Continue".
6. After confirming the installation location, click "Install". During this process, you will be required to authenticate using Touch ID or your device password. After successful installation, a prompt "The installation was completed successfully." will appear.
Install HoRNDIS Driver
HoRNDIS is an open-source USB tethering driver for macOS (Mac OS X) that is vital for proper firmware update and flight controller data export functionalities.
Following the installation of DJI Assistant 2, a system pop-up will automatically appear to prompt the installation of the HoRNDIS driver as depicted below:
In this window, enter your device password* and press the Enter key. Wait for the system to indicate "Process completed", and then restart your computer.
* When entering the password, the entry will not be displayed on the interface. If you enter it incorrectly, a "Sorry, try again." message will appear. At that point, re-enter the correct password.
After closing the "Installation Successful" page, you will see the page shown below:
Enter your device password on this page:
Press the Enter key, and once the "Process completed" prompt appears, restart your device:
After restarting, follow the path "System Preferences > Security & Privacy > General" to verify if the driver has been installed correctly as shown in the image below. If there is no "xxx app is blocked from loading" message or any other alert, it means the installation was successful, and you can use DJI Assistant 2 without issues.
Now you have completed all the installation steps and can use DJI Assistant 2 normally.
